135 - Draft control needs to be full back to lift implement?
   / 135 - Draft control needs to be full back to lift implement? #1
IIIBradIII
SC
MF135 diesel. So what does it mean when the Draft lever needs to be pulled full back/up to get the other lever (forget the name but it's the one closer to the operator) to lift the implement on the 3pt?
   / 135 - Draft control needs to be full back to lift implement? #2
Thats the way the 3pt hyd work, with the draft control lever in the fully raised position you can then operate the 3pt lift with the Position control lever, this is the correct way to use it. The draft control is used for soil engaging implements only such as plows.
Have you tried the 3pt lift with the draft control fully raised ??
Ok thanks - I was just confused then. Yep, the position control lever lifts the BH fine with the draft control fully raised.
   / 135 - Draft control needs to be full back to lift implement? #4
THe draft control position should have nothing to do with the ability to raise the 3 PH lift arms with the position control lever. The draft control should only raise the 3 PH when it senses overload (when correctly positioned), and the position lever should raise the implement regardless of where the draft control is set. I have seen some tractors that if the draft control was all the way up, it wouldnt lower, but never the other way around.
Well for some reason the draft control on this 135 has to be full up for the position lever to be able to raise or lower the 3pt. It's a tractor I'm considering buying - that's why the question.
   / 135 - Draft control needs to be full back to lift implement? #6
I don't know were you are getting your information from but i can assure you that all 100 series Massey Fergusons have to have the levers as i stated
   / 135 - Draft control needs to be full back to lift implement? #7
G'day don't mean to sound smart but this sounds like it comes from someone who hasn't had alot to do with massey hyd, i used to think the same until i came to work where i am now and my boss has 50+yrs of massey experience, even he say's that they are good when they are working but some of their ideas are a bit strange
Jon
   / 135 - Draft control needs to be full back to lift implement? #8
JJ is right, I actually had mine apart a couple of years ago now and had adjusted everything by the manual, mostly because someone who owned the tractor before me had tried the same I think. It is necessary to have the draft control lever up on my 135, and as JJ said it is used for ground engaging implements.
   / 135 - Draft control needs to be full back to lift implement? #9
Hello,
I have a similar situation, my position lever is rusted stuck in the up position and I have to use the draft lever to raise and lower the 3 point. So when I get it unstuck I will find out if my hydraulics work or not.
v/r
Mike
   / 135 - Draft control needs to be full back to lift implement? #10
G,Day Garry I notice you dont have any RED tractors in your collection maybe sell some and buy a nice old Red one :).
Now you know how the hydraulics work, just kidding.
One point to note that when sold the operating instructions say to use the draft lever when operating a tipping trailer for example,with the position control lever in constant pump and the draft lever in lower the pump will only supply the hydraulic pressure required to tip the trailer thus avoiding the ram being subject to a dead head pressure spike and possibly doing the ram no good .
for tractors fitted with pressure control you can use the pressure control side of the system where you operate by selecting the low pressure to start and slowly raise the pressure to give the desired speed .
Happy Days.:)
hutch
Valvoline 6 cases manual transmission oil plus 11 (A53117)
Valvoline 6 cases...
2009 Skeeter SL190 19ft Boat with 21ft Boat Trailer (A51694)
2009 Skeeter SL190...
2004 FREIGHTLINER COLUMBIA (A53843)
2004 FREIGHTLINER...
2019 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2019 INTERNATIONAL...
DoD 88-20041 12.5kVA Brushless Diesel Generator (A51691)
DoD 88-20041...
Hyster H225E (A47384)
