1320 Wont Start
   / 1320 Wont Start #1
SRF34
I stalled the machine trying to dig out a rock. Now it wont start. Getting plenty of juice from the battery but wont even turnover. P Brake is in, clutch is in, 3pt pressure is off. Thoughts? Thanks.
   / 1320 Wont Start #2
Is it making any noise when you try to start it? clicking or anything? starter could be jammed...you can try tapping it with a hammer. I'm not familiar with the 1320 but make sure all levers are in place. I know I have knocked my shifter out of medium gear and when its in between, it wont start.
   / 1320 Wont Start #3
Check the main fuse that is located by the starter in a black assembly. If not this , look under left side rear fender under 4 wheel pto levers and make sure all wires are attached to switches.
   / 1320 Wont Start
Figured it out. The rod connected to the clutch pedal that actuates the kill switch was bent - must have been bent while I was working on stumps, rocks etc in the woods. Once I bent it back, it made contact with the switch and all is good again. Thanks for the advice.
Generac Yanmar 5000Watt Heavy Duty Diesel Generator (A51691)
Generac Yanmar...
Quick Attach Skid Steer Quick Claw Grapple Industrial Grapple Rake (A53473)
Quick Attach Skid...
John Deere Gator XUV835M 4X4 Utility Cart (A48082)
John Deere Gator...
2016 ETNYRE TRI-AXLE DETACH TRAILER (A53843)
2016 ETNYRE...
2008 OVERLAND TANK KILL TRAILER (A52472)
2008 OVERLAND TANK...
2000 Trail King TK70SA-48.2 T/A 43 Ton Hydraulic Slide Axle Step Deck Trailer (A52377)
2000 Trail King...
