1300D pto lift capacity
   / 1300D pto lift capacity #1
cowboy357
Platinum Member
SC Kansas
I posted in attachments about what I,m trying to do here , Pics are on page 3 .
http://www.tractorbynet.com/forums/attachments/147128-3-pt-carryall-box.html
I,m wondering what the rear lift capacity for this little tractor is. As the Dump box & rear 3 point carry all attachment is around 375 lbs total . To me it seems to be to far back & puts to much strain on the rear of the tractor .
With the box sitting on top of the attachment rails , it will lift it but only about 4 inches . The tractor then starts to make some odd Squeeling noises at that point , so I didn,t push it & figured I,d ask for help & advice here .
I know I have a few options, of wether to just scrap the idea of using the dump box & continue with bulding a carry all box .
OR , Put lower pins on the Dump box itself & top link connect to get it closer to the tractor .
Shorten lower & toplink arms ? I Know no matter what , I,ll have to add weight to the front but not sure how much depending on which way I decide to go .
I bought the DB pretty cheap with the Ideas of using it for this & for My forklift to have a stand in box for tree trimming & such. Just looking for ideas to decide which way to go. Thanks & hers a few pics in case You dont want to go to the other thread. Bob
   / 1300D pto lift capacity #2
Cowboy .357
I have a 1300D and what you are showing in the photos is too much leverage strain on the 1300D. My 1300D will pick up that weight, but I need even more weight on the front of mine (75pounds currently) to properly pick up with the PTO my 400 pound rotary cultivator, and it is near the rear wheels. I believe I need 200 pounds of wieght on the front of my 1300D.
I bought a John Deere cart to pull behind my 1300D (from Home Despot) and it works great, plus is light but thick and tough plastic that I can pick up easy.
Thanks lowveld . I,m beginning to agree with You. I had 200 lbs on the front & even with that it didn,t seem very stable & seemed a bit to much weight on the front for steering. So I,ll just keep it for My forklift & build a wooden box for the carryall frame. I,ll post Pics of what I cobble up :D .Thanks again , Bob
1982 LeeBoy Motor Grader (A52748)
1982 LeeBoy Motor...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
2015 FORD TRANSIT XLT (A52472)
2015 FORD TRANSIT...
2018 Infiniti Q50 AWD Sedan (A51694)
2018 Infiniti Q50...
