1300D pto lift capacity
   / 1300D pto lift capacity #1
cowboy357
Platinum Member
SC Kansas
I posted in attachments about what I,m trying to do here , Pics are on page 3 .
http://www.tractorbynet.com/forums/attachments/147128-3-pt-carryall-box.html
I,m wondering what the rear lift capacity for this little tractor is. As the Dump box & rear 3 point carry all attachment is around 375 lbs total . To me it seems to be to far back & puts to much strain on the rear of the tractor .
With the box sitting on top of the attachment rails , it will lift it but only about 4 inches . The tractor then starts to make some odd Squeeling noises at that point , so I didn,t push it & figured I,d ask for help & advice here .
I know I have a few options, of wether to just scrap the idea of using the dump box & continue with bulding a carry all box .
OR , Put lower pins on the Dump box itself & top link connect to get it closer to the tractor .
Shorten lower & toplink arms ? I Know no matter what , I,ll have to add weight to the front but not sure how much depending on which way I decide to go .
I bought the DB pretty cheap with the Ideas of using it for this & for My forklift to have a stand in box for tree trimming & such. Just looking for ideas to decide which way to go. Thanks & hers a few pics in case You dont want to go to the other thread. Bob
   / 1300D pto lift capacity #2
Cowboy .357
I have a 1300D and what you are showing in the photos is too much leverage strain on the 1300D. My 1300D will pick up that weight, but I need even more weight on the front of mine (75pounds currently) to properly pick up with the PTO my 400 pound rotary cultivator, and it is near the rear wheels. I believe I need 200 pounds of wieght on the front of my 1300D.
I bought a John Deere cart to pull behind my 1300D (from Home Despot) and it works great, plus is light but thick and tough plastic that I can pick up easy.
Thanks lowveld . I,m beginning to agree with You. I had 200 lbs on the front & even with that it didn,t seem very stable & seemed a bit to much weight on the front for steering. So I,ll just keep it for My forklift & build a wooden box for the carryall frame. I,ll post Pics of what I cobble up :D .Thanks again , Bob
2012 Dodge Grand Caravan Van (A50324)
2012 Dodge Grand...
Pallet Fees (A50775)
2019 Ford F-250 4x4 Crew Cab Pickup Truck (A50323)
2019 Ford F-250...
Vermeer 630A Stump Grinder (A50515)
Vermeer 630A Stump...
2012 Ram 4500 Chassis Vesralift Bucket Truck (A50323)
2012 Ram 4500...
1989 W-W Stock Trailer (A50514)
1989 W-W Stock...
