12x32 rims
/ 12x32 rims #1
khamill2000
central Kansas
Mahindra 2815 HST
Anyone know where I can locate a pair of 12x32 rims? Aparrently these are no longer made and I have to have a pair before I can move a tractor.
/ 12x32 rims #2
You will find them on 13.6-32 tires... maybe that helps when asking around for them...
The more common 11Wx32 rims can also be used with 13.6-32 tires.
There are two measuring systems, or actually three: first they had 12-32 tires which measured 32" rim diameter, and 12" width from heel to heel. Later, the measuring system for this same tire became 13.6-32 because the absolute width of the tire was measured, not the width of the heel.
Later there came metric sizes, a 520/65 R32 tire has a width of 520 mm, the distance from rim bead to wheel circumference is 65% of the width (65% of 520 is 338mm) and the rim size is 32" from heel to heel.
Older tires with no aspect ratio mentioned, are standard 85% ratio height/width.
HARGEE 18' BOGGIE AXLE METAL TRAILER (A63291)
HARGEE 18' BOGGIE...
2016 John Deere 470G Hydraulic Excavator (A64194)
2016 John Deere...
Wooden Indian Statue (A64127)
Wooden Indian...
250 Gallon Tank (A64127)
250 Gallon Tank...
ROAD GEAR ALUMINUM HEADACHE RACK (A64277)
ROAD GEAR ALUMINUM...
2022 Blue Diamond Brush Cutter (A64126)
2022 Blue Diamond...
