12volt electric over Hydraulic Pump
/ 12volt electric over Hydraulic Pump #1
nwngunner
Maquoketa, Iowa
806Farmall 1650Oliver
All right i have a dump box insert for my pick up, and it uses a 12volt hydro pump. It is power out gravity down. There is a valve that is pushed in to the valve body when power is applied to the solenoid. I am trying to find a replacement solenoid. Mine is burnt up and wont release the pressure of my dump box. This of course had to happen with 3/4 of a load of gravel on.
I am going to attach pictures so you can see what i am looking for. This is older, and i am not having much luck finding it online. Any help that you can give me would be amazing, i am trying to get gravel down and now i am stuck. I was hoping it was just a simple switch bad or wiring. Had to be almost the worst possible item.
Well thanks for all the help, i found a dump valve and having to replumb everything.
JOHN DEERE 8 SHANK CHISEL PLOW (A63291)
JOHN DEERE 8 SHANK...
1998 CHEVEROLET 1500 LONG BED PICKUP TRUCK (A59905)
1998 CHEVEROLET...
2025 SAWYER 85BP20 20FT T/A ENCLOSED BUMPER PULL TRAILER (A59912)
2025 SAWYER 85BP20...
2026 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2026 SDLANCH...
2008 DOOSAN G25 GENERATOR (A58216)
2008 DOOSAN G25...
2010 Sauber 25' Tag Trailer (A62613)
2010 Sauber 25'...
