electrycmonk
- Joined
- Nov 6, 2018
- Messages
- 212
- Location
- Near Denton, TX
- Tractor
- Satoh 370 diesel & Cub Cadet 7260 Diesel 4WD standard
Okay here are some questions based in ignorance. The old hay bales spike that is mounted in bed of truck had a electric motor die a rusty death.
As this system is a power up gravity drain dedign, may I safely assume that one could safely do the following idea even if my vocab is wrong?
Hydraulic questions
1) to put a "Tee" in-line to cylinder for a PSI gauge to show realtime psi load & leak down rate?
2) Can I safely set up a splitter type valve or diverter type valve to run a different/ 2nd cylinder temporarily - but, only when the original cylinder is not in use and obviously when the pressure is near zero?
I tried to search the forum and guess my vocab limiation is taking its toll again.
Hydraulic questions
