12v socket on tag
   / 12v socket on tag #1
farmhand96
Kubota b26
I have a 2006 Honda trx 250 ex sporttrax is it possible and how hard is it to hook up a twelve volt socket to my ATV so I can run a twelve volt compressor for whence and my friends go trail.riding
   / 12v socket on tag #2
Red to pos terminal, black to frame.
I would run an inline fuse on the red as close to the battery as possible. I would match the size of the wires to the wires that come with the 12volt device or the same size that comes with the in-line fuze.
Or, you could find a "key on" or "key on, engine on" wire coming out of the steering column and tie into one of them. I'd use a fuse as close to the power source as possible no matter how I hooked it up.
Get a good one; outdoor/water resistant.
   / 12v socket on tag
Thanks hey do u think I should upgrade the battery
   / 12v socket on tag #4
Nah,
I run a compressor from a factory outlet on my ATV, never had any problems. Its good for reinflating tires at 2 to 10 PSI.
It wouldn't run the smallest inverter tho, not enough amps.
   / 12v socket on tag
Well.I have to install one because it doesn't have one on it
2017 CHALLENGER MT465E TRACTOR (A51406)
2017 CHALLENGER...
2001 International 4700 Dump Truck with Compressor, VIN # 1HTSCAAN91H363922 (A51572)
2001 International...
2005 Mack CV713 Granite T/A Roll-Off Truck (A50323)
2005 Mack CV713...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
378754 (A51573)
378754 (A51573)
20X8 SHIPPING CONTAINER (A52472)
20X8 SHIPPING...
