12v cordless drill to run off truck 12v
   / 12v cordless drill to run off truck 12v #1
WantedWolf
South Alberta
ditch witch 6510
I didnt want to hijack kossetx's drill thread, but has anyone used an old 12volt cordless drill and converted it to run "corded" from a vehicals 12v power?
I havent seen a new 12v drill in years so the old drills should be a dime a dozen with a box of dead batterys.
   / 12v cordless drill to run off truck 12v #2
That should work no problem if you don't mind dragging around a very heavy battery. It would run a long time on a vehicle battery.
   / 12v cordless drill to run off truck 12v #3
Just get a cig lamp plug and adapter and 20' of zip cord..run it from the ca.. or from open hood with bat clips.. or from a carry-around motorcycle battery..etc.
soundguy
   / 12v cordless drill to run off truck 12v #4
I have an old 12 volt drill that I did as someone else suggested with -- soldered a cigarette lighter plug to and hooked it up:D -- works fine
   / 12v cordless drill to run off truck 12v #5
I did that with my old Crafstman after I couldent get batteries for it.
I took the battery pack apart holes some heavy lamp cord to were the batteries were and drilled a hole for wire to come out.
I'v only used it 2 or 3 times that way but it dose work.
btw I did fuse it at about 10 amps in one leg of the wire.
there is a youtube hack video on it but the drill was delta
tom
   / 12v cordless drill to run off truck 12v #6
There's also a guy on e-bay who sells individual batts and instructions to rebuild your bad batt pack. You'll have to do a search though, bec I can't remember his name.
Id only use it on vehical, I never like the cig plugs but that might be the best option. I dont even own a single cordless tool. I used many at work and they all died at the worst time, and bats are ussually to expensive to have more than 2.
If I come across a 12v drill I might do this. I suppose a 14v would work too?
   / 12v cordless drill to run off truck 12v #8
My 12V driill is still operational but old enough that the batteries are no longer available. I took the exhausted battery pack to my local Battery Plus store and they rebuilt the pack. Picked it up the next day and it's as good (or better) than new - can't even tell how they opened it to put in new cells. I also have a 18V drill & circular saw that I use for heavier work but that old drill is convenient for small quick jobs.
   / 12v cordless drill to run off truck 12v #9
I work with a guy who uses a 12volt Dewalt at work. He likes the 12volts because if the battery ever dies he can hook up a set of jumper leads to the cigarette lighter and charge the battery in transit. 15 or 20 minutes later he is back up and running.
Tom
   / 12v cordless drill to run off truck 12v #10
Hmm. I have a couple old 6v and 7v drills with bad batteries.. hmm.. I have 6v tractors.. ;)
I think I need to revive those old drills!
soundguy
2025 JMR Tree Boom Skid Steer Attachment (A53421)
2025 JMR Tree Boom...
2006 FORD F750 XL SUPER DUTY SERVICE TRUCK (A51406)
2006 FORD F750 XL...
2019 Fontaine EQ1 Hydraulic Equalizing Spreader (A52377)
2019 Fontaine EQ1...
MISC WRENCHES (A53843)
1993 PETERBILT 362 SLEEPER (A54607)
1993 PETERBILT 362...
Toro Workman MDX Utility Cart (A51691)
Toro Workman MDX...
