Gale Hawkins
Super Member
- Joined
- Sep 20, 2009
- Messages
- 8,260
- Location
- Murray, KY
- Tractor
- 1948 Allis Chambers Model B 1976 265 MF / 1983 JD 310B Backhoe / 1966 Ford 3000 Diesel / 1980 3600 Diesel
http://www.orschelnfarmhome.com/15-gallon-spot-sprayer/ctl16754/cp58349/si5182792/cl1/
Had a few minutes yesterday evening before Source Code started so I hit up TSC and Orschein's. TSC had 12v 15 gallon spot sprayers for $100 with nice 4 amp 1 GPM 35 PSI then I found the above one at Orchein's (not nation wide but like TSC) for $50.
The specs are about the same but the $100 one pump motor is fan cooled but I did not see it as a $50 plus. It is marked $80 in the store so $30 off is nice.
Now that we have the EZGO PSD electric golf cart with the rear seat/utility box I thought this would be good to have. We have rock drive at the house and the church 1/4 mile down the road.
The set up must not weigh over 10 pounds so I just plan to put a rubber mat on the cart bed and maybe put a rubber strap over the tank to stablize it. I will test it with water later this week. I did connect it to the Blazer battery in the parking lot last night to hear it hum. :thumbsup:
