1260 massey
   / 1260 massey #1
Timothy joe
Michigan
1260 massey ferguson
I have a1260 that will not start. Was running fine shut it off and nothing when you turn the switch. You can pull start it but it will not shut off with the key after starting it.I replaced the neutral safety still nothing. I would appreciate any help or suggestions.
   / 1260 massey #2
I have no knowledge of your particular model but it sounds like there is an electric shut off on the pump.
On my Kubota RTV it closes for a few seconds, long enough to kill the engine, and then snaps back to the "run" position. If it had a bad connection or the shut off was trashed it would stay in the "run" position all the time.
That would be the place to look next.
   / 1260 massey #3
Take the ignition switch out.
Snap it apart.
Clean the contacts.
Apply some dielectric grease or Never-Seez.
Put to to getter and install.
   / 1260 massey #4
I missed the "pull start" part.
Never mind. Listen to JerryG.
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A53473)
2024 BCL...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2019 Club Car Carryall 1700 4x4 Diesel Utility Cart (A51691)
2019 Club Car...
1pallet of miscellaneous items (A53117)
1pallet of...
1985 International 1754 Material Spreader Dump Truck (A51692)
1985 International...
