122 Cub good deal?
   / 122 Cub good deal? #2
Seems like a decent deal. Even better if it doesn't smoke. Rebuilding these old Kohlers isn't a big deal anyway. The rear PTO is a somewhat rare option and increases the value of the tractor by a significant amount. If you have the money, go for it. I doubt you'll regret it.
AJ
   / 122 Cub good deal? #3
Sorry. I read it wrong. i thought he was selling the 122 for $400. $500 is probably a little on the high side. If the 1250 is in similar shape, it's probably a better deal.
AJ
AJ
Thanks i may look more into the 1250
   / 122 Cub good deal? #5
I guess it depends on what you intend to do with it. I don't see any rear lift on the Cub with the rear PTO, and I don't know what implements you could find that would work with the rear PTO or where you'd find them. If you're intention is to sell off the rear PTO then maybe that is a different matter.
The engine on the 1250 is an rubber iso mount engine, and those iso mounts have a limited life. They are also pricey items to replace. If not replaced in time, the aluminum oil pan will wear down against the frame, and you'll have to replace it, too. Make sure the electric PTO works because that is another high dollar item. Another weak spot is usually the muffler box will be all cracked up.
The older Cub engine is easier to get to the air filter and carb for routine service because you don't have the side panels. The 1250 side panels were designed to control noise and to help direct air flow over the engine.
Really, they are two different machines, and you need to be careful to be sure everything works as it should or you can sink some bucks replacing parts. Just be careful to look the 1250 over very carefully for the things I mentioned because they can go unnoticed and set you back some money if not caught.
Thanks for all that information. i'm going to put off getting a Cub IH for a little bit.I have a project i just started(tow yard sprayer) plus the way the economy is i hate to spend money on stuff i don't need also i need a new air compressor.But when the time comes i'mgoing to look this post up.thanks
Sky Trak 10054 Legacy 10K Telehandler (A54865)
Sky Trak 10054...
Skid Hydraulic Hoses (A50775)
Skid Hydraulic...
2018 DRAGON 150 BBL ALUMINUM TRAILER (A55745)
2018 DRAGON 150...
POLARIS RANGER 500 RTV (A51406)
POLARIS RANGER 500...
2016 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A55852)
2016 Peterbilt 320...
