1210 rims
/ 1210 rims #1
mwoody
Chandler Arizona
ford 1210 4WD
Hi, I'm new on here and don't know if I'm asking the right question. Can someone tell me what other type of tractor rims will fit on the rear of a Ford 1210 4WD. I have AG type wheels but they are rusted out. My tractor is at our home in La Pine OR. and I didn't measure the bolt pattern before we left. I would like to know the bolt pattern if I could. Thanks in advance Mike
/ 1210 rims
Thanks, This helps some. What I would like to have and can't seem to find is the actual bolt hole pattern and the dimensions associated with that pattern. The pattern is not a common size from what I have been told! If I had the dimensions I could perhaps cross reference these rims to some other manufacturers rims. From reading some post these rims are the same size as the Satoh S370. I'm very frustrated! Thanks for your help! Mike
/ 1210 rims #4
It's a metric pilot and hole pattern, but I don't know it offhand. A one piece wheel for 8x16 tires (would also work on 9.5x16 tires) show being available SBA336103240 one piece wheel $225. through your local New Holland dealer.
If you're looking used, 1110, 1210, 1120 and 1220 wheels will all be the same. West Kentucky Tractor Parts is one used yard that speciailizes in Japanese compacts.
/ 1210 rims #5
Before I left for work today I measured mine. I wouldn't consider my measurements good enough for fabbing anything. My thoughts are that there is some degree of standardization on bolt patterns. My measuremets may help ID a pattern.
I used the metric tape and it looks like the bolt circle is about 120mm, or just less than 4-3/4". The center hole is approx. 90mm, or 3-9/16". Hope this helps.
/ 1210 rims
Thanks so much. I know these measurements will help! Mike
/ 1210 rims
Thanks, I finally found a set of rims in Canada that were reasonably priced (Fawcet Tractor Salvage) They were great to deal with! Mike
