12 volt switches
   / 12 volt switches #11
There are loads of Marine supply stores out there, and on ebay, that sell great, weatherresistant 12 volt switches. I got mine thru
rryachtservice rryachtserviceinc | eBay
they have been great, and fit right into standard rocker switch openings. Ive also looked at custom ones from
OTRATTW
   / 12 volt switches
Thanks for the links. I'm going to spend some time going through them. Just finished a couple hours of mowing after spending some time looking at the dash I think I'm going to try to find push button switches like the factory hazard light switch. With all the choices in the links you guys provided someone must make a switch like the factory Kubota. Now just got to look.
   / 12 volt switches #14
The best waterproof switches out there are the mil spec toggles that can be found in all sorts of configurations. If they can survive military use (and I used many while in), they can survive anything! Search for Cutler Hammer, Eaton, Honeywell, etc on Ebay. That's all I use for switches that will experience dust, water, snow, etc. You can also add boots to further protect them.
Here's a quick search....
mil spec toggle | eBay
   / 12 volt switches
Is there a mil spec push button? I'm now really leaning towards trying to match the factory Kubota push button they use for the hazard lights.
Although those toggles look pretty good, I'm going to order a few for some other uses. Thanks.
   / 12 volt switches #19
I got some of these from Ebay I used on my tractor. Small, cheap, easy installation, illuminated.
12PCS 12V LED Round Screen Lighted illuminated Rocker Switch,BRYG
   / 12 volt switches #20
I have had good results with this dealer. Don't let the name distract you they are marine wireing supplier.
Genuinedealz
2016 FORD F-250 SUPER DUTY (A58214)
2016 FORD F-250...
2015 Ram 5500 IMT 3203i 4,000lb 2 Ton Crane Service Truck (A55852)
2015 Ram 5500 IMT...
2012 Ford F-350 Crew Cab Knapheide Service Truck (A55852)
2012 Ford F-350...
CATERPILLAR 20" PIN ON BUCKET (A52707)
CATERPILLAR 20"...
2014 Ford Taurus AWD Sedan (A55853)
2014 Ford Taurus...
2015 Peterbilt 567 (A55973)
2015 Peterbilt 567...
