12 volt outlet
   / 12 volt outlet #1
presnewt
Thomson, Ga
Steiner 440,Kubota MX5400 HST cab
Has anyone here ever installed a 12 volt outlet kit on a Ventrac or Steiner? If so, how difficult is it to do?
   / 12 volt outlet #2
Both front and rear outlet kits are available from Ventrac. Don't know about Steiner.
   / 12 volt outlet #3
I have installed the front kit on my two units. Instructions are easy to follow. Not very difficult - on a scale of 1-10 maybe a 3.
   / 12 volt outlet
Hi Bruce, I am a georgia guy also, what do you use your ventracs for, what attachments do you use?
   / 12 volt outlet #5
I have done the rear on my Ventrac 4500Y. My dealer did the front installation (as well as one channel of front hydraulics) prior to delivering the tractor to me. The front installation was in connection with the rotary broom. The rear installation was for possible future use. The rear installation was a piece of cake, but I have done a lot of electronics work and electrical wiring over the years, so I am probably not in a position to be a good judge for someone who lacks experience.
   / 12 volt outlet #6
I have a few outlets.
Both use Anderson connectors, a small one is to power my fueling pump and it has an automatic breaker near the battery.
A larger one is for my jumper cables while this is unprotected but very well isolated and even the HD cabling is sheathed in rubber tubing, the +12v cable is also very short.
2017 Caterpillar 326FL Hydraulic Excavator (A50322)
2017 Caterpillar...
JLG MANLIFT (A50854)
Walking Floor Trailer 43ft (A50322)
Walking Floor...
2016 PETERBILT 587 (A50854)
2016 PETERBILT 587...
2016 Ford F-150 Ext. Cab Pickup Truck (A50323)
2016 Ford F-150...
2004 CATERPILLAR 140H MOTORGRADER (A51406)
2004 CATERPILLAR...
