12 volt Fuel Transfer Temp Limit
   / 12 volt Fuel Transfer Temp Limit #1
oldballs
Elite Member
Kansas...USA
Kubota B2620 , Case 448 , Kubota B2650
Anybody know if these 12 volt DC Fuel Transfer Pumps work at less than 32 Deg F...pumping diesel fuel? I just bought a new model that makes no statement in that regard. This model is good for gasoline as well as diesel and has an aluminum body. The cast iron models state..."durable through all types of weather"........whatever that means.
   / 12 volt Fuel Transfer Temp Limit #2
Hard to say for sure but diesel doesn't really thicken up until it is really cold or if it has moisture in it. I have never had problems pumping diesel out of my transfer tank in my pickup with the 12volt pump even in temps near zero.
Thanks bdog............I called the Fillrite company line, and they said it is functional from 0 deg F to 150 deg F.......pumping diesel. Thanks again.
Obviously, at either of those extremes, I won't be tractoring.
   / 12 volt Fuel Transfer Temp Limit #4
I have a Fillrite and use down to -30F with no problems.
Good luck, Fred
2016 Nissan Altima 2.5 Sedan (A54815)
2016 Nissan Altima...
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
2008 Ford F-350 (A53422)
2008 Ford F-350...
2008 KZ Sportsman Police Bunk 5th Wheel Tri-Axle Travel Trailer (A54815)
2008 KZ Sportsman...
2018 E-Z Beever M12R Towable Brush Chipper (A50322)
2018 E-Z Beever...
2019 Fontaine EQ1 Hydraulic Equalizing Spreader (A52377)
2019 Fontaine EQ1...
