12 Volt air compressor
/ 12 Volt air compressor #1
Dwellonroof
Batavia, Ohio
John Deere 3046r
What 12v compressor would be for portable remote use for tractor or zero turn tires just to top them off or to stager back to trailer or garage?
/ 12 Volt air compressor #2
I'd recommend a Viair pump. I have one mounted underneath my pickup behind a baffle exposed to all the road crud for the last 10 years and it's still working fine.
Viair compressors
/ 12 Volt air compressor #3
I have one of the $6X (they move around in price, usually $60-70) Harbor Freight compressors and it's a beast, way quicker than the cheaper ones, the one that's about $30 isn't bad either is just slower...
Depends on what you are trying to do, the big HFT compressor has been reliable for me, have a couple friends with them and they work good enough to use for going offroading, air the tires down (35" tires aired down to like 8psi) while wheeling then air up with that in about 20 minutes to about 25psi, that's all 4 tires...
/ 12 Volt air compressor #4
I have several from vans with factory air shocks, years ago. Cheap and still working.
Bruce
/ 12 Volt air compressor #5
This is a timely post, as just yesterday I was wondering how I could keep an air compressor in the field to blow the sawdust out of my sawmill. I have my little pancake pump, but a 12V pump with auxiliary tank would be handy.
/ 12 Volt air compressor #6
I use a Viair 300P; 2.3 cfm, 150 psi max., 33% duty cycle @ 100psi. Not cheap, but you get what you pay for and its worth it when you consider that you are using it for an emergency repair when you don't want to fart around with a piece of junk.
Check the duty cycles on the cheap compressors to find out how long it will take to pump up a tire.
/ 12 Volt air compressor #7
I have a Viair, say 8 years old, still great.
I do let it rest, for heat, say every 1/2 tire (refilling after beach drives).
It is the standard for 'off roaders'.
2017 KALMAR OTTAWA T2 4X2 SPOTTER TRUCK (A60430)
2017 KALMAR OTTAWA...
2015 MACK CXU613 T/A 6X4 MID ROOF TRUCK TRACTOR (A59910)
2015 MACK CXU613...
Spray Daddy 400 Gallon 30 Ft Sprayer (A64047)
Spray Daddy 400...
1986 Eager Beaver B9D0W 20ft. 11 Ton Tri Axle Dovetail Tag A Long Tailer (A61568)
1986 Eager Beaver...
2016 WEILER P385A ASPHALT PAVER (A62129)
2016 WEILER P385A...
2011 Dodge 2500 Service Truck (A63116)
2011 Dodge 2500...
