Sprayer 12 volt 25 gal. sprayer
   / 12 volt 25 gal. sprayer #1
professor
jackson tn
Allis Chalmers 416S John Deere LX280, John Deere Z225 zero turn yanmar 1401 , Oliver 550 Special, Oliver 75 Lawn Tractor, New Holland 3930 4WD, Mitsubishi BDF2 Dozer
My pump on my sprayer is on-demand and lately the pump keeps running when I release the wand trigger. I have also noticed there is a decrease in pressure when I engage the wand. I have checked all the fittings and they are tight. The pump is a Shurflo gold series less than a year old. Any suggestion as to the problem?
Thanks
   / 12 volt 25 gal. sprayer #2
check your intake hose and pump intake fitting. if it's sucking air on the intake side it won't show up as a leak.
   / 12 volt 25 gal. sprayer #3
Might check the strainer on the line in the tank. If it's not clear, it'll affect your pressure output. HTH Mark
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
2023 Kubota U27-4 (A50120)
2023 Kubota U27-4...
8ft Fork Extensions (A50322)
8ft Fork...
P.T 10' Mower (A50121)
New Kivel 4200 lb. Skidloader Forks (A50774)
New Kivel 4200 lb...
2013 International DuraStar 4300 Box Truck, VIN # 3HAMMAAL1DL085200 (A51572)
2013 International...
