12 JD Tandem Disc
   / 12 JD Tandem Disc #1
rpmranch
Texas
Kubota M7040 & Kubota B7610
Need to know if a Kubota M7040 cab 4wd with loader will pull a 12 foot disc.
   / 12 JD Tandem Disc #2
Sorry, but need to know more info. If you want, I can set you up with a 12' disk that needs a D8 to pull them.:eek: As far as what I would call a normal disk, my 12k pound 75hp tractor will only pull our 12'JD disk on basically flat ground. But there are other disks out there that you should be able to pull. Do you have an idea of what the 12' disk that you want to pull weighs? What size disks pans? What type of ground? Flat or hilly?
Our disks have 22" pans that are 3/16" thick, weigh in the 4000lb range I believe, is yours similar to this? Most of our ground is hilly, I usually just pull our 8' JD offset disk and don't have any problems.
   / 12 JD Tandem Disc #3
   / 12 JD Tandem Disc
The disc is an older JD BWA. It has 20 inch discs spaced at 9 inches. I do not know the weight. It is not an offset disc. I will be using it on hilly ground with sandy loam soil.
2017 Kia Cadenza Premium Sedan (A51694)
2017 Kia Cadenza...
2017 Bobcat E20 Excavator (A52384)
2017 Bobcat E20...
2016 Atlas V4 Towable Light Tower (A51691)
2016 Atlas V4...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2013 COACHMEN CATALINA TRAVEL TRAILER (A52472)
2013 COACHMEN...
2016 TAKEUCHI TL8 SKID STEER (A51242)
2016 TAKEUCHI TL8...
