Mowing 12' finish mower
/ 12' finish mower #21
On terrain like around your area (Cedartown) I can understand stability, but does loading the tires help with a pull behind mower?
(I came thru Cedartown TWICE yesterday...)
David from jax
/ 12' finish mower #22
Just curious, why would anyone want to load the tires on a mowing machine that they are concerned about ground compaction? (or is this a shootoff of the original post?) I would think the widest tire size available and zero added weight would be the best deal...
David from jax
I loaded the tires since I use a loader, not for the mower. I do find the R3's hook up a ton better than the R4's I had on dry grass. Much more surface area. I do think the ride quality suffers when you load the tires (much less air to compress, a higher rate also).
I've had loaded R4's and R3's. If I were to do it again I'd probably leave them unloaded and use wheel weights when needed. I do think the loading helps with stability on side slopes though.
/ 12' finish mower #23
I've got a 13'6" Rhino mower that made my 1020 overheat on my hill. Its 35 pto hp. I think 1020's are around 3800 lbs but I haven't felt I needed more weight. Power isn't a problem now that I'm getting my 3020 utility broke in with it!
Tim
/ 12' finish mower #24
Tim,
Welcome to TBN!
A 1020 weighs in about 4800 lbs without ballast or weights and is about 38 to 40 hp. So it would compare closer to a 5000 series tractor handling implements, horsepower not withstanding. Compare the `1020 to the current 4320 for hp purposes.
The 1020 and 3020 are a great pair of tractors to have I have had 820, 3020 and 4020 all were very good.
Steve
/ 12' finish mower #25
Thanks Steve,
I dug out my 1020 manual and it is heavier than I thought, but the horsepower is 38 at 2500 rpm, less at 2100 which is the 540 pto speed. It should be able to handle the mower w/o overheating but maybe 42 years of use has something to do with it.
Tim
/ 12' finish mower #26
Thanks Steve,
Tim
With the 3020 for heavier work I would use the 1020 without ballast or weights to handle the lighter chores.
See TractorData.com John Deere 1020 tractor information
Steve
/ 12' finish mower
Lots of good info here, thanks guys!!!
Now the question in my mind is can I actually fit a 11-12' batwing mower in enough places to justify the cost of the tractor big enough to run it, plus the mower itself... At this point I'm leaning towards a no. Just seems like it would take such a large area to turn it around, and be hard enough to trim with, that I'd be better off with a 72" MMM, RFM, or just getting a big ZTR. I like the idea of having the tractor to do all the other stuff with also though. Mainly the idea of having a loader to move snow, mulch, gravel, etc... plus the multitude of attachments for the 3pt. Starting to back off to something in the size of a 2305/2320/2520. The 2305 doesn't seem like much of a step up from my x720, but I don't know.
/ 12' finish mower #28
herrick,
For commercial work where you make your living I still lean towards a 4x20 series. I would assume you already have the trimming mowers covered.
As far as a batwing mower that depends on the terrain too, not much info to go on about obstacles, tree spacing to advise on.
Steve
/ 12' finish mower
The location I would be using a batwing is greatly varried... there are a couple wide open 2-3 arce areas where I have no dout it would work great. From there I have everything from big ditches to small front yards. One of the things I was hoping was to be able to pick up a school or park district mowing contract where something like the batwing would come in handy for the sports fields.
/ 12' finish mower #30
It sure seems that 2-3 acres is a hard way to justify a batwing unless it pays big time and they want it done in a very short period of time.
Maybe you can find a used one to make it more viable.
D.
/ 12' finish mower #31
D.
Frontier makes a real nice 90inch finish mower that I would imagine makes short time of mowing. I looked at one when buying my last 4120 but have not bought it yet...
I know it has to be cheaper than a batwing.
/ 12' finish mower
There's a total of about 5-6 acres open that I have now, and I'm hoping to pick up another large account where something of this size may be useful (like a school or park). I will not be making any purchases until I have a contract from another place, as it would definately be a waste with only this one account. Still a lot of thoughts running through my head, and I have pleanty of time to think for now. :D
/ 12' finish mower #33
What I have found that works for me is design/build the parks and outdoor areas rather than mowing and maintaining them. Much more room for profit this way, people are much more likely to pay a higher one time fee to landscape initially.
Steve
2018 LARK UNITED MANUFACTURING S/A GUARD SHACK (A58214)
2018 LARK UNITED...
2002 BMW 325Cic Convertible Coupe (A61569)
2002 BMW 325Cic...
Tandem Axle Rear Truck Frame (A59228)
Tandem Axle Rear...
2014 Ram 1500 Crew Cab Pickup Truck (A61568)
2014 Ram 1500 Crew...
1999 Ford F-150 4x4 Pickup Truck (A59230)
1999 Ford F-150...
2022 Horizon Trailer (A55973)
2022 Horizon...
