12.5-38 mtd shutting down
   / 12.5-38 mtd shutting down #1
coyote4x4
mtd12.5 38
Hi all,
I have n 2002 mtd 12.5 38 that just started shutting down after it warms up. Carb was rebuilt in the spring and it ran like a bear until now. I have fuel to the carb, tank was flushed when the carb was done. IT starts right up but after it warms up it starts to pulse then it shuts down. Any help is appriciated.
   / 12.5-38 mtd shutting down #2
First check to see if its losing spark when it dies. If it still has spark, could be a loose valve seat on the exhaust valve. they would come loose from the block when they got hot, that would be loss of compression. If it has a fuel solenoid make sure its working and has power. Just a few thinks to look at. Need to find the root cause, fuel, electrical or mechanical
FELLOWS PAPER SHREDDER (A53843)
FELLOWS PAPER...
2012 KENWORTH T800(INOPERABLE) (A53843)
2012 KENWORTH...
377811 (A48836)
377811 (A48836)
2017 Ford Fusion Hybrid Sedan (A53424)
2017 Ford Fusion...
2024 JOHN DEERE 6155M LOT NUMBER 9 (A53084)
2024 JOHN DEERE...
