$115.00 Pulverizer
/ $115.00 Pulverizer #1
wkasr1
S.C/
Kubota B7800
Finished building my pulverizer and thought I would try to post some pics. I bought the 10" I beam and the "A" frame and a few steel pieces. I think the only thing I would do different is try to weld a little better. I began to get real good with the grinder tho.
I really enjoy this forum with all of its great ideas. Thanks to all for ideas and help. Billy
/ $115.00 Pulverizer #2
Looks great .. quite a bit of welding you've done...scozz
/ $115.00 Pulverizer #3
Great work!
Please post some before and after pictures of some ground you've pulverized. Let's see this thing in action!
/ $115.00 Pulverizer #4
Great job!
But before Gatorboy says it...you said pictures...But we only see one! /forums/images/graemlins/grin.gif
Look forward to seeing more.
Typing this on my PDA during the ball game commercials...hope it makes sense by the time I get it posted!
Have to say it again...that looks soooooooo good!
Almost fogot...Go Steelers!!!!! /forums/images/graemlins/grin.gif
/ $115.00 Pulverizer #5
Great Job.
Yes please, more pics with close ups of how you put it together. I promise not to yell at your welding!
Thks.
Ron
/ $115.00 Pulverizer #6
That is a really slick looking job - but I have a question. What exactly is a pulverizer for? This is sort of a newbie question but I am asking because sometime next year or the summer after I will finally get to the point where I can finish off the landscaping on my house and I am wondering if this is an implement that could do me some good. I've got a welder and am always looking for a good winter project. Thanks
another pic
Jim I'm fairly new to this tractor thing but I do a little new home construction landscaping here in SC. Most of the lots are 1/3 to 1/2 acre. We usually till, boxblade to move dirt, and finish off with either the boxblade set way back so you are working with just the rear blade to get a smooth job or use a pulverizer. Sometimes you can get by with just a pulverizer if there is not too much growth. Anyway the roller on a pulverizer gives the yard a SUPER smooth and flat finish
that is unmatched with a boxblade. I know there are lots of people on this site who are very knowledgeable on this subject
but this method seems to work in this part on the state.
/ $115.00 Pulverizer #9
Darn you! I have been trying to avoid the temptation to buy a welder but things like this make it harder.
Beautiful job. Could you drop by my house next weekend and whip one of those out for me?
I had not seen one of those before and it looks like something I would like to use. I need to cover up some of the holes my dogs have dug and would like to aerate the soil too. Looks like that would do both very nicely.
Bill Tolle
/ $115.00 Pulverizer #10
Here is what a pulverizer will do to the ground. Pulverized Sample I built one myself. They are so much superior to a LS box for putting the finishing touches on a new yard. They leave you will a great surface to sow grass seed.
Yours looks great, your scarifers are set up like mine. Yours looks much better than mine, but then again, I only have about $30 in mine. Here is the link to mine. My homebuilt pulverizer.
There is a lot of work to these things. Lots of cutting, drilling, and welding!
Bill thanks for the comments. I don't think I'll be in Texas any time soon- tho I sure would like to be. I have about 20 or so hours in this thing but I really don't have a real good drill press (for 25 pairs of holes) plus all the other holes. Also this thing gets pretty heavy real quick. I had to use the Kubota to lift and move around because my shop is kind of small. All in all it's a simple piece of equipment and I'm sure you would have no problem in making one.
/ $115.00 Pulverizer #12
Ok, I can see this thing has uses even without the front part.......which could be a rake or anything else 3 pt. I want to know how you made the roller and pins.
thanks
/ $115.00 Pulverizer #13
A nice set of pictures, a materials list and measurements would be really nice. If I had those I could build one for myself.
I got a pipe 5" dia. by 5'-6" and had a friend with a plasma torch cut the end plates out of 3/8" plate. He also cut a hole in the center 1" dia. for the 1" steel rod which goes all the way trhough. I tacked welded the end plates on with the 1" rod and trued the rotation similar to using a lathe.Once the roller ran true I finished welding the end caps and the 1" rod.
The spikes are 3/4" pieces of a 10' ground rod. Each piece is 1 1/2 " long welded to the roller. The ground rod is copper coated steel which should hold up pretty good.
Mad-- I looked at several pulverizers on the net and some sites even break down a parts list and how they are assembled. Also I went to a local Agri Supply and looked at one first hand. Theirs was a little different- not as heavy duty as some other models. A pulverizer similar to the one I built sells for around $1000. Not much in material but a lot of time.
/ $115.00 Pulverizer #16
Billy, great job.
Are you making others for sale?
Bob
Bob thanks for the reply. I really can't weld well enough to make things for the public. If I payed someone for mine I would expect it to be better.
/ $115.00 Pulverizer #18
Thanks for the info guys. I have a TIG welder that I bought a number of years ago when I was doing a bunch of car work. The thing sat dormant until this summer when I bought the tractor and pulled the thing out to weld up a few things for the tractor. The pulverizer looks like a nice little project that I could get some real use out of. I have seen the professional built ones and they are real $$. If the materials don't cost too much I don't mind spending the time to build one. Thanks again.
1999 Coachman Catalina RV/Camper VIN # 3FCMF53S2XJA29020 (A65563)
1999 Coachman...
2006 KAWASAKI BAYOU 250 ATV (A60430)
2006 KAWASAKI...
Great Dane Van Trailer 1989 (A63689)
Great Dane Van...
Case SV280B (A62177)
2013 Kobelco SK26LC (A64126)
2013 Kobelco...
2005 DRAGON END DUMP TRAILER (A65643)
2005 DRAGON END...
