1120 throttle friction disk issues
   / 1120 throttle friction disk issues #1
espacef1fan
Shopping for a tractor
My 1120’s throttle won’t hold its setting/position so I believe the friction disks are worn.
I don’t see any procedures for adjustment in the manual and new friction disks are $68. A PIECE!
Anyone have any other fixes or ideas I should/could try?
   / 1120 throttle friction disk issues #2
The hand throttle friction washers(key 6) that I see in 1120 PC are L41465 Washer ADD 3.73 USD 7.46 USD
The throttle linkage is challenging to disassemble but you're correct on needing to change friction washers.
   / 1120 throttle friction disk issues #3
Tx Jim
You think tightening down nut #3 against spring #7 wouldn't increase the friction enough to improve holding?
Looks like an adjustment possibility there..
Edit: see now that they are not nuts.. but called "grommets" in the parts list..so no adjustment possible.
Those “nuts” are bushings
And I was mistaken, the cheaper pieces are the friction disks according to the manual(which I reread after misreading)
   / 1120 throttle friction disk issues #5
Tx Jim
Only way to tighten is to install new friction washers or adding shim washer to increase spring pressure on worn friction washers.
I have new friction washers on the way. $3 ea.
Thanks for making me double check my work
   / 1120 throttle friction disk issues #7
You're welcome
Jim
The hand throttle friction washers(key 6) that I see in 1120 PC are L41465 WasherADD3.73 USD 7.46 USD
You weren’t kidding on it being annoying to disassemble.
I had to buy some new punches(lost mine in the move) but that was the biggest snag.
Next up on this beast is changing all the fluids/filters and new tie rods.
After that? Fixing the wiring/gauges/lights
2018 JLG 1644 4x4 15,600lb High-Capacity Rough Terrain Telehandler (A52377)
2018 JLG 1644 4x4...
2016 Chevrolet Tahoe SUV (A51694)
2016 Chevrolet...
2018 Dodge Charger Sedan (A51694)
2018 Dodge Charger...
SULLAIR 185 PORTABLE AIR COMPRESSOR (A51406)
SULLAIR 185...
2014 Ford Explorer AWD SUV (A51694)
2014 Ford Explorer...
2025 Star EV Capella 2+2 Electric Cart (A51694)
2025 Star EV...
