mrtractortire
Is it normal to hear a clacking noise while moving around in high range? The tractor has 3 ranges, and whenever I want to scoot across the yard in 3rd range, i hear an annoying clacking in the transmission. The tractor pulls just fine though.
And... whenever I take it out of gear up top, but leave the range selector in high range, it wants to pull forward slightly when i let out on the clutch.
And... If i cut the tractor off while the tractor is in high range, as soon as the enging quits turning, the whole tractor shakes pretty bad the last bit.
is this a problem, should i worry as long as it is still moving?
Thanks to all
-tractor
Thanks to all
-tractor
