Loader 110TL leveling
   / 110TL leveling #1
brs077
Cobleskill
NH WM 40
I've got a Workmaster 40 with the 110TL loader. I'm trying to find out if there is any adjustments to the cylinders to level the arms. When I put a 8' pusher on it, the right side (as seen from behind the wheel) hits the ground and the left side is still 2-3" high. I can use hydraulic pressure to make the other side contact the ground of course, but that slightly lifts the right front wheel and makes the right side dig into the stone driveway more than the left, causing it to scalp slightly.
   / 110TL leveling #2
My first thought is something is bent that isn't as noticeable when the bucket is on or on the pusher or mount. My second thought is to check tire pressures all the way around the tractor.
   / 110TL leveling #3
Try adding air to the right rear or deflate the left rear some
   / 110TL leveling #4
You need to park the tractor on a level surface. Use a bubble level to start checking to see what is tilted. is it possible that the pusher is not welded perfectly square?
2007 Hyundai Santa Fe SUV (A55973)
2007 Hyundai Santa...
40006 (A55788)
40006 (A55788)
2006 International Bucket Truck (A55973)
2006 International...
1982 LeeBoy Motor Grader (A55302)
1982 LeeBoy Motor...
2014 Ford Fusion Sedan (A56859)
2014 Ford Fusion...
2018 John Deere XUV560E 4x4 Gator Utility Cart (A56857)
2018 John Deere...
