Loader 110TL leveling
   / 110TL leveling #1
brs077
Cobleskill
NH WM 40
I've got a Workmaster 40 with the 110TL loader. I'm trying to find out if there is any adjustments to the cylinders to level the arms. When I put a 8' pusher on it, the right side (as seen from behind the wheel) hits the ground and the left side is still 2-3" high. I can use hydraulic pressure to make the other side contact the ground of course, but that slightly lifts the right front wheel and makes the right side dig into the stone driveway more than the left, causing it to scalp slightly.
   / 110TL leveling #2
My first thought is something is bent that isn't as noticeable when the bucket is on or on the pusher or mount. My second thought is to check tire pressures all the way around the tractor.
   / 110TL leveling #3
Try adding air to the right rear or deflate the left rear some
   / 110TL leveling #4
You need to park the tractor on a level surface. Use a bubble level to start checking to see what is tilted. is it possible that the pusher is not welded perfectly square?
TAKEUCHI TL150 SKID STEER (A51242)
TAKEUCHI TL150...
2025 JMR 36in Mini Skid Steer Bucket Attachment (A50322)
2025 JMR 36in Mini...
HUSKY 135 PSI AIR COMPRESSOR (A50854)
HUSKY 135 PSI AIR...
RoGator RG1100C (A51039)
RoGator RG1100C...
2014 MACK GU (GRANITE) (A50854)
2014 MACK GU...
2012 Ford Escape XLS SUV (A50324)
2012 Ford Escape...
