1100c muffler bolt mod
/ 1100c muffler bolt mod #1
MountainBuck
TN
Ventrac 4500P; Kubota RTV-X1100C
I just performed a 300 hour service on my 1100c. The muffler bolt was EXTREMELY difficult to remove. I felt like I was on the verge of breaking the bolt head off. Actually, I'm surprised I didn't.
Yes, I have removed the bolt before at the designated time.
For a moment, I was thinking of just putting it back in and never servicing it again.
However, I kept going and it came out.
So I thought about putting "anti-seize" on it and re-installing, but figuring it was the soot that was the problem, I decided to do one better.
The bolt is magnetic so I don't think it was titanium.
I first used a wire brush dremel attachment and removed the soot.
Then I decided to use an abrasive disk to taper the end of the bolt, where it gets the most soot.
The few sparks it threw were orange, so I do think it was some grade of steel.
It was still difficult to install, so I again turned to the dremel and took off the high portions of the threads on the entire length of the bolt. This allowed for easy re-install.
Roast me ??
/ 1100c muffler bolt mod #2
I found mine fairly tight as well. I use anti-seize and so far haven’t had a problem.
/ 1100c muffler bolt mod #3
Mine broke a couple years ago, I drilled it and put a smaller bolt thru, very hard metal ! When I had hole thru it I did the tap with mallet while running , but no significant soot came out, will worry about it if exhaust seems constrained , otherwise leave alone. I figure my Bx2660 tractor has same engine and its exhaust has no such maintenance requirements.
CAT 963 GP Bucket (A68134)
CAT 963 GP Bucket...
2022 Land Pride QH30 3 Point Quick Hitch Tractor Attachment (A66734)
2022 Land Pride...
2015 GMC SIERRA 3500HD (A67714)
2015 GMC SIERRA...
Connibear Hotshot Applicator (A64912)
Connibear Hotshot...
2009 MACK CHU613 (INOPERABLE) (A67714)
2009 MACK CHU613...
John Deere 5320 (A64911)
John Deere 5320...
