1100 Ford smokes
   / 1100 Ford smokes #1
sauber
Since I purchased my 1100 this spring it has been blowing black smoke from the exhaust. It runs good and starts fine, even in the cold. Injectors, pump, or maybe something simple? It is obviously running rich. I don't use it much so I rarely check fuel comsumption. Any Help?
Thanks...Dan
   / 1100 Ford smokes #2
Lets start with the really easy stuff.... how does the air filter look?
   / 1100 Ford smokes
All new filters and fluids.
   / 1100 Ford smokes #4
Check air and fuel filters first.
   / 1100 Ford smokes #5
How much smoke? Some smoke may be normal for an engine that old. My 20 year old 2120 also blows some black smoke, particularly until it warms up.
Andy
   / 1100 Ford smokes #6
Will it smoke with the air filter removed?
Soundguy
   / 1100 Ford smokes
It smokes pretty much the same warm or cold. I have not run the tractor with out the air filter. It has a different smell than diesel and seems like it is loaded up. I put a straight pipe on it thinking the muffler was plugged. It ran a little better, but still smoked bad.
thanks...Dan
   / 1100 Ford smokes #8
Might be time for injector work, and while they are out.. the dreaded compression test..
Soundguy
HYSTER STRAIGHT MAST FORKLIFT (A51246)
HYSTER STRAIGHT...
(APPROX 15) 2" X 6" X 68" THICK TUBING (A51247)
(APPROX 15) 2" X...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
2011 New Holland Boomer 90 MFWD Utility Tractor (A53473)
2011 New Holland...
1995 Generac 94A05603S Diesel Generator (A51691)
1995 Generac...
UNUSED HURRICANE MSC2020F ALL-STEEL CARPORT (A51248)
UNUSED HURRICANE...
