10w-30w UTTO equivelants/swapping
   / 10w-30w UTTO equivelants/swapping #1
davemhughes
Ft.Riley KS
SAME 40hp turbo charged 4cyl diesel w/fel
Just out of curiousity what can you substitute for UTTO. I am just wondering if the UTTO is 10w-30w can you substitute it for some other 10w-30w type fluid. If you can't why not if the weight is the same. Was telling the wife I wanted to drain and switch out my Transmission/hydraulic fluids but needed to find some synthetic 10w-30w UTTO and she asked why couldn't you use something else in 10w-30w........said i don't know. My neighbor says he runs a mix of UTTO and 10w-30w Mobil 1.
   / 10w-30w UTTO equivelants/swapping #2
Completly different additive packages. UTF's have a additive package that is suited for hydraulic systems, extreme preasure gear's, wet brake and clutch systems, etc. The additive package in engine oil does not have any EP additives and no additives for brake/clutch systems. Your friend that is mixing his UTF with engine oil shouldn't because he is thining out the additive package for extreme preasure gear applications and any wet brake/clutch system he might have. It's best to use the correct fluid for the correct application. Just because the weight of a lubricating oil may be the same does not mean it can be used for everything. Would you use a 80W gear oil in your engine, a engine oil in your automatic transmission in your car, automatic transmission fluid in your engine? No, probably because of the same reason why should stick with a UTF in sump of your tractor.
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
FUEL TANK (A50854)
FUEL TANK (A50854)
2005 International 4300 Heil Dump Truck (A50323)
2005 International...
2014 VOLVO VHD (A50854)
2014 VOLVO VHD...
71054 (A49346)
71054 (A49346)
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
