10mm Hydraulic line?
/ 10mm Hydraulic line? #1
JerryRigger
Austin, TX
I have finally finished my loader for my Mitsubishi D2000 tractor and am ready to plumb in the hydraulics. The high pressure line from the pump measures close to 10mm OD. Does that sound right? Or could there be that much paint on 3/8 dia tubing. Actuall measurement is .420 inches OD.
Also I'm mounting my control valve on the right side. While looking at it while sitting on the tractor should the far right lever operate the yoke or the bucket?
thanks for any help
/ 10mm Hydraulic line? #2
Would it be easy to take off one line, take it to a hydraulic shop, and they could fit it up?
Me, I'd measure it, then make four trips before I got the right size. So I learned from my mistakes and try to idiot proof myself, at least a little.
ron
/ 10mm Hydraulic line? #3
I know it may be a pain to remove but the line ID is what is important first.Then matching fittings.Ron is right take existing line to get another made.
If your luck is like mine you will still be making 2 trips.
/ 10mm Hydraulic line? #4
thanks for any help
Traditionally the left spool works the lift arms and the right spool works the bucket. The high pressure line from the hydraulic pump is less than 1/2" OD? That sounds kinda small...
Thanks for the info. I'll do as suggested and take that section of line to a shop.
/ 10mm Hydraulic line? #6
The grey market Yanmars use a Weatherhead compression fitting to connect their loader hydraulics. #7255x8 It requires an adapter ferrel C-5165x8x12
213135 (A64276)
213135 (A64276)
2018 AUTOCAR XPEDITOR GARBAGE TRUCK (A63276)
2018 AUTOCAR...
2018 Ford Explorer AWD SUV (A64557)
2018 Ford Explorer...
Indian Totem Pole (A64557)
Indian Totem Pole...
2000 LINCOLN TOWNSCAR (A64278)
2000 LINCOLN...
2024 JOHN DEERE TURF GATOR (A63276)
2024 JOHN DEERE...
