1085 head gasket
/ 1085 head gasket #1
wrench57
Southern Idaho
1951 Farmall Super C
I am needing to replace the head gasket on a 1085 tractor. Any thing I need to watch for or change and also need the head bolt torque. Any help would be appreciated.
/ 1085 head gasket #2
Head bolt torque is 100 ft lbs, my Perkins manual doesn't show the torque sequence for the 318 so cain't advise you of any special procedures.
/ 1085 head gasket
Thank you JJ. I really appreciate your reply.
/ 1085 head gasket #4
G'day just start in the middle and work your way out when pulling the head down, also check the rocker shaft and rockers as some of these had a bad habit of wearing
Jon
/ 1085 head gasket #6
If your head is set on studs (as mine was), prepare yourself for a workout. You have to lift the STRAIGHT OUT or it will bind on the studs. Not easy to do!
I will check the service manual on the torque sequence and get back to you tomorrow.
I took the time to torque the head with smaller increments, going over many times to make sure it would sit properly.
Good luck!
Woods 72" Brush Cutter (A64047)
Woods 72" Brush...
2019 Ford F-550 4x4 Altec AT40G 40ft. Insulated Bucket Truck (A64556)
2019 Ford F-550...
YALE FORKLIFT (A63291)
Beverage Truck Body (A64556)
Beverage Truck...
2022 Mac Trailers 48ft. T/A Walking Floor Trailer (A64556)
2022 Mac Trailers...
1995 FORD F-SERIES S/A GRAIN TRUCK (A64278)
1995 FORD F-SERIES...
