1050 Leaking MFWD seal on right front tire
   / 1050 Leaking MFWD seal on right front tire #1
Eric67ct
Bethany, CT
1983 John Deere 212, 1988 John Deere 1050
I have a 1050 with a leaking seal somewhere behind the right front wheel. It's a MFWD. Is this a DIY repair? Has anyone out there tackled a job like this?
Thanks,
Eric
   / 1050 Leaking MFWD seal on right front tire #2
I did it on my 950. Not that big of a job but more than likely the seals have worn grooves in the upper housing and you will need to sleeve. Hoye sells a sleeve but it痴 too thick and will likely require enlarging the hole in the lower hub. Here is a pic of the sleeve I used which allowed me to use the original part number seals and did not require modification of the hub. You will need to be careful to reinstall the shims exactly as removed as they establish the relationship (backlash) between the gears. Mine no longer leak one drop.
   / 1050 Leaking MFWD seal on right front tire #3
I few more pics that might helpDF5AFC68-802F-48AA-9BCA-B923B7EE89C1.jpeg2AB57693-9800-451B-9449-03CFCF85AFE1.jpegC93C5287-7D5D-4FC7-B042-D5E197D8A782.jpegB15D2F06-D507-4316-A451-04EC15C6D937.jpeg6A27DECF-0DC4-4243-98F1-F8C4B782D88B.jpeg
   / 1050 Leaking MFWD seal on right front tire #5
What did you use to get sleeve all the way up on shaft?
2014 PETERSON 4700B HORIZONTAL GRINDER (A51242)
2014 PETERSON...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
12 FLATBED W/ 300GAL WATER TANK (A50854)
12 FLATBED W/...
2023 TAKEUCHI TL10V2 SKID STEER (A51242)
2023 TAKEUCHI...
2013 FELLING  SKINNYNECK TA LOWBOY (A50854)
2013 FELLING...
2015 CATERPILLAR 272D2 WHEELED SKID STEER (A50458)
2015 CATERPILLAR...
