Mowing 1046 mower deck bearings squeeling
   / 1046 mower deck bearings squeeling #1
sdk8103
My mower deck is so loud this year and it sounds like the bearings in the spindles are bad. This mower only has 82 hours on it and it screams when I engage the blades. Has anyone else had this experience?
   / 1046 mower deck bearings squeeling #2
Are they greaseable?
There are grease fittings on the spindles and I have greased them. It doesn't make a difference.
   / 1046 mower deck bearings squeeling #4
Are both spindles sqeeling? I would disassemble one and while on bench, you should be able to feel if bearings are tight.
   / 1046 mower deck bearings squeeling #5
Are both spindles sqeeling? I would disassemble one and while on bench, you should be able to feel if bearings are tight. It may be the idler puley making the noise. Make sure belt is installed correctly also. You need to isolate the noise. A piece of hose held to the ear and spindle or a piece of steel held to spindle and ear or a mechanics stethiscope.
I don't think it's the pulley since I had the belt off and hand spun everything. The pulley turns and spins very freely, but the blades feel like there are bad spots in the bearings that you can feel while turning the blades by hand. I will try the stethoscope trick to see if I can narrow it down.
   / 1046 mower deck bearings squeeling #7
Sounds like no grease is getting to the bearings. Can you disassemble the spindles? Anyway to get some penetrating oil in bearing to free it up? This may get you a little more life out of it. Take the grease zerk fitting out; then force some penetrating oil into bearing. I am guessing here.
The noise is coming out of the spindles. I can't believe the bearings are shot after only about 70 hours. Anyone else experience this? I am not sure if all 6 bearings will need replacing, but at least 3 will since the noise is coming from all 3 spindles. At $15 a bearing plus the time to do it, this ticks me off on a 2 year old mower with so few hours.
   / 1046 mower deck bearings squeeling #9
Talk to your dealer; maybe CC will help you out. You can run it till they fail.
   / 1046 mower deck bearings squeeling #10
If it's only 2 years old isn't it still on warranty? If so, make Cub fix it and save yourself the $
AMADAS SPC-6 LOT NUMBER 257 (A53084)
AMADAS SPC-6 LOT...
Kubota Salt-Spreader (A52384)
Kubota...
ROME GK-14 LOT NUMBER 131 (A53084)
ROME GK-14 LOT...
New/Unused AGT 3000PSI Hot Water Pressure Washer (A51573)
New/Unused AGT...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A52377)
2012 Vermeer...
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
