104 LOADER QUESTIONS, SEEMS WEAK ??
/ 104 LOADER QUESTIONS, SEEMS WEAK ?? #1
expressfish
TEXAS
MAHINDRA 2015
Hi and hello , first post here and long time lurker. I was a tractor owner wanna-be for a while there until I finally pulled the trigger on a 2015HST. My question has to do with the loader capacities. I understand the loader should be able to handle 900 some odd pounds. Well this weekend I bought some railroad ties to build a retaining wall. I was really surprized that the loader would not lift 4 ties. It would only hand 3 at a time ?? Is there an adjustment some where on the hydraulic system or weak pump ??? I figure at 200lbs a tie it was only lifting about 600 lbs. seems kinda weak---or not ?
/ 104 LOADER QUESTIONS, SEEMS WEAK ?? #2
It would depend on how close into the bucket the ties were. I believe loader lift capacity is at the bucket attachments points, and then you subtract the bucket weight. So if they advertise 900 lbs, and the bucket weighs 150 lbs, then your lifting capacity capacity becomes 750 lbs.
Im sorry, I should have mentioned this was with the forklift attachment. I slid the ties out of the bed of my truck onto the forks and pushed them all the way back so the load wouldn't be at the tip of the forks.
/ 104 LOADER QUESTIONS, SEEMS WEAK ?? #4
Samething, subtract the weight of the forks. You could lay one of them on a bathroom scale and check the weight.
/ 104 LOADER QUESTIONS, SEEMS WEAK ?? #5
How were you carrying the ties???
Most manufactures advertise the lift capacity @the pivot pins, as JJ mentioned. But seldom does anyone lift anything at the pins.
Most loaders loose about 25% by the time you get to the bucket edge.
You can lift 915 lbs @ the pins. 915-25%= only about 686lbs at the bucket edge. The further forward you go (like adding clamp on forks) the less you can lift.
so I guess thats about right, 600lbs of railroad ties and 150lbs of forks pretty much sums it up. It still beats the **** out of manual labor ! If I may add, attached is pic with some sort of hydraulic box. In the lower center there is a kinda selector lever that has two positions. A bolt holds it in place, what are the two positions for ??
/ 104 LOADER QUESTIONS, SEEMS WEAK ?? #7
That selector is used to change the hydraulic flow route. One position is without a loader and the other is with a loader.
thanks
2018 CATERPILLAR CS44B SMOOTH DRUM ROLLER (A65053)
2018 CATERPILLAR...
HONDA generator (A64557)
HONDA generator...
Skid Steer Power Broom (A65640)
Skid Steer Power...
Bestway 750 Sprayer (A66285)
Bestway 750...
(2) FIFTH WHEEL PLATES (A65643)
(2) FIFTH WHEEL...
2005 Freightliner Tropi-cal T396 39ft. Class A Motorhome (A64557)
2005 Freightliner...
