1026r faster hydraulics
   / 1026r faster hydraulics #1
swick1
Platinum Member
WV
John Deere 1026R
I've got a 1026r with a 260 backhoe that I have been doing commercial work with and I was wondering if there is anyway to speed up the hydraulic pump flow by either turning up the pump, having it modified by a shop for more displacement, or replacing it with a higher flow unit? This may heat up the fluid more, but I think I could counteract that by installing a supplementary reservoir or adding an oil cooler.
It would also be nice to get about 10% more force out of the bucket curl and boom lift cylinders :) Any ideas are welcome!
I had thought about adding a pto pump and reservoir just for the backhoe, but it would be a tight, almost impossible fit, leaving the center pto as the only option. It turns at 1000 rpm if i am right, but i'm decreasing ground clearance by going this route!
thanks for the brilliant suggestion
   / 1026r faster hydraulics #4
Maybe you don't need a full size backhoe but really you should have considered a 2520 to start with if you need just a little more machine.
   / 1026r faster hydraulics #5
Agreed, by the time you spend the money to modify the thing, you could have taken the bath on the trade in and bought a 2520. The 2520 runs at a higher pressure, 2400 PSI vs. 2000 PSI and has 40% more flow.
   / 1026r faster hydraulics #6
Short answer is NO, the is not a way to do this. The pump is mounted directly to the engine so fitting a larger one would not be easy, plus all the lines and coolers are sized to match the OEM pump.
   / 1026r faster hydraulics #7
I'm new to this, but I dare say a cut is not great for commercial backhoe work, a scut would seem to me the wrong tool for the job. With the demand for that unit you should be able to get a good price if you decide to trade up...
I really don't have any interest in trading or selling it... at least not yet. I just wanted a free tractor, so I started working it, but now I am doing jobs that are a little beyond its design envelope. A bigger tractor couldn't cut my grass very well and would require a bigger trailer :)
Thanks for the free advice. I'm used to the motorcycle world where these sort of conversions/alterations are more common. Financially, it doesn't make sense for me to spend the money on a bigger unit because this isn't my day job. I'd still like a JD 110 though, so maybe in the future...
Just out of curiosity, can someone point me to the exploded view of the engine / pump assembly?
   / 1026r faster hydraulics #10
Register for free at www.jdparts.com
There is a quick tutorial linked in my signature if you need help with it. I can't really link to the picture since you need to log in.
2020 CATERPILLAR 306 CR EXCAVATOR (A60429)
2020 CATERPILLAR...
JOHN DEERE 330G SKID LOADER (A58214)
JOHN DEERE 330G...
case 370 glass door never installed (A56436)
case 370 glass...
New/Unused CFG Industrial H15R Mini Excavator (A57453)
New/Unused CFG...
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
2015 GENIE GTH-1056 TELESCOPIC FORKLIFT (A59823)
2015 GENIE...
