Mowing 1025r Mid Mount Mower
   / 1025r Mid Mount Mower #1
dmbtree82
PA
JD 1025r
Hi everyone,
I got my 1025r recently and am wondering if the deck is lifting properly. I think the lowering is correct; not much to it. When I raise the deck it only seems to raise maybe 2 inches. Would anyone be able to tell me if that is correct? I have taken it off/on several times while doing loader work, but am pretty sure it went back on correctly. Any advice would be appreciated. Thanks.
   / 1025r Mid Mount Mower #2
I've got a 1026 and mine raises up about the same distance when I'm mowing. If I ever think something may not be right, I look to make sure the PTO is fully engaged and the deck is locked on.
It appears to be in the brackets properly and the driveshaft should be fully in place.
It just barely raises it off the ground and hits on a 3/4" lip when leaving the shed.
   / 1025r Mid Mount Mower #4
Mine raises higher than that. Have you adjusted the turnbuckles on the mower lift link? If you haven't already seen it, here's a link to the manual that may help:
OMLVU25573_A2
(You may have to copy and paste this)
Thanks,
I'll check where the turnbuckles are and tighten them up a bit.
1967 Ford F100 (A47384)
1967 Ford F100...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A52748)
2017 Yale GLC050VX...
2006 Ford Expedition 4x4 SUV (A50324)
2006 Ford...
2008 Bobcat S250 Skidloader (RUNS) (A50774)
2008 Bobcat S250...
2019 Chevrolet Silverado 4x4 Extended Cab Knapheide Service Truck (A50323)
2019 Chevrolet...
14' Bi-Parting Gate (A47384)
14' Bi-Parting...
