1025-6r FILB w/MMM - store w/ implements on or off?
   / 1025-6r FILB w/MMM - store w/ implements on or off? #1
geol
linden nj
garden tractor
For you guys who have one, is it easier to store separate, and just mount the implement for the task at hand?
Mine is on its way. I think I'd like to build a small out building to house it, but am unsure how big.
I see myself needing the mower most frequently.
I'm not sure how much more space would be required (foot print needed for the H120, and 260A, and how much room needed to pick up / drop off).
In practice, what do you guys find yourselves doing?
Thanks, George.
   / 1025-6r FILB w/MMM - store w/ implements on or off? #2
It depends on what you use most frequently. I store my mower on its side next to the wall. The hoe and loader stay on unless I'm plowing or tilling. Sometimes I take the hoe off for mowing if I know I won't be using it for a long time. I also remove the front bucket when I mow.
You need room to drive up to the hoe and loader. You shouldn't use the hoe without the loader so you can park the loader in front of the hoe. I'd say you need a 2 car garage to store everything separately
   / 1025-6r FILB w/MMM - store w/ implements on or off? #3
Length with loader & BH is hair under 15'. Width will be close to 5' when you consider the BH stabilizers. You need to restrain them to keep them from leaking down & taking more room during non-use.
Nick
2021 CATERPILLAR CB2.7 DBL DRUM TANDEM ROLLER (A52705)
2021 CATERPILLAR...
COOPER LIGHTING CAT. NO. MHEP-22/28-175-MT (A53472)
COOPER LIGHTING...
ATLAS 84" BOX BLADE (A51243)
ATLAS 84" BOX...
2013 FORD F-150 XL EXTENDED CAB TRUCK (A51406)
2013 FORD F-150 XL...
1995 Rinker Captiva 190 (A53473)
1995 Rinker...
PENDING SELLER CONFIRMATIONS (A54313)
PENDING SELLER...
