1020 a mess
   / 1020 a mess
Finally getting back around to working on the rust bucket. I have all of the fluids drained out. The drain plugs look like they may have had a washer or o ring on them that rotted or possibly is just a collection of grease and dirt. Does anyone know if they need a washer or seal of any kind? I can't find anything in the manual.
   / 1020 a mess #12
You can use a little Teflon tape on the threds if it feels loose. I would not add a loose washer that could make it leak, some plugs will hav a built in lip much like a washer and that might work. If it did not leak I would use the existing plug.
   / 1020 a mess
Thanks. Put them back with no tape or seals. Holding all fluids perfectly.
   / 1020 a mess #14
Drain plug should have sealing washer
2 ea-A4827R Washer - WASHER,SPECIAL ALUMINUM ADD 1.76 USD
2022 ALLMAND LIGHT TOWER (A58216)
2022 ALLMAND LIGHT...
2243 (A58376)
2243 (A58376)
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
1751 (A58375)
1751 (A58375)
2015 Toyota Highlander XLE SUV (A56859)
2015 Toyota...
LOT: (6) Pneumatic Tools, (3) Impact Wrenches, (2) Cut-Off Tools, (1) Grease Gun (A59076)
LOT: (6) Pneumatic...
