Eric_Phillips
Platinum Member
I noticed on my tractor the manufacturer used R16 hose for the loader. This is a 27hp CUT so things are a little tight. I am in the process of designing my rear remotes. It seems the R16 with half the minimum bend radius as R2 would be advantageous. What would be the down side of using R16 over R2?
I am also planning on mounting the quick disconnects on a plate mounted to the tractor. How much space should I leave between 3/8" QDs so as to be able to use them easily?
