1000 series with slipping transmissions
   / 1000 series with slipping transmissions #1
dqdave1
Veteran Member
N. E. Ohio
tc- 29d
Curious to what brand hydro unit the posters that are having transmission problems have installed in their machines. I understand CC installs two different brand hydro units in its units. Peerless is one brand and the other is a hydrogear unit.
   / 1000 series with slipping transmissions #2
All hydrogear...the "slipping" problem is a known issue and Cub has a service advisory out for it.
I contacted my dealer about bulletin and they called CC. I was there when he called, they said they only have a bulletin for noisy idler pulley. Do you have the bulletin # for idler spring; slipping problem?
   / 1000 series with slipping transmissions #4
I haven't actually seen it and I am not a dealer. I believe however that the bulliten is #CC-497.
Good luck sir.
   / 1000 series with slipping transmissions #5
So is there a stamp, or label on the hydro that says who it is made by? My Parents just got a 06' LT1042 ( DOM 12/06 ). I would like to know if it is a Peerless or Hydrogear.
Thanks.
Will
   / 1000 series with slipping transmissions #6
If you look from the rear, under the tractor you should see a tag which should tell what it is. That's where mine is on my 06-1045.
   / 1000 series with slipping transmissions #7
I could be wrong, but I think most of the hydro problems were with the 2005 models. As far as I know, the 2006 models are not having the same issues. From what I remember, MTD changed something in the hydro to make it cheaper to build and it bit them in the backside, so they changed it back.
AJ
UNUSED FUTURE BK56 56" HYD BACKHOE DIGGING ARM (A57193)
UNUSED FUTURE BK56...
UNUSED FUTURE MCLG60 CURVED LOG GRABBER (A57193)
UNUSED FUTURE...
2008 Featherlite Trailer, VIN # 4FGE853218C108480 (A53424)
2008 Featherlite...
2016 CATERPILLAR 336FL EXCAVATOR (A51246)
2016 CATERPILLAR...
2018 Toro Workman GTX Electric Utility Cart (A54811)
2018 Toro Workman...
2020 Freightliner M2 106 Elgin Whirlwind Series MV Street Sweeper Truck (A55852)
2020 Freightliner...
