1000 FPS Air Guns (Gamo Hunter)
   / 1000 FPS Air Guns (Gamo Hunter) #1
PBinWA
Platinum Member
WA
Kioti NX55, Mahindra 2615, Case 36CXB, Case W4, Volvo MC85C
Do any of you have any experience with one of the Gamo (or other) 1000 feet per second air rifles? Gamo web page
I'm thinking of getting one to use as a deterrent for the large antlered rats that graze my property.
I'm wondering what the effective range would be on one of these for delivering a good sting to the backside (or anyside) of one these pests.
I know this may not be the most effective deterrent but it would be fun. I also don't want to damage them too much just deliver a sting. I'll have to wait until the fall to use something a little more lethal.
   / 1000 FPS Air Guns (Gamo Hunter) #2
The spring operated [or "single pump"] air guns are really cool, but I don't know that you'll find a happy medium for your task:
The higher velocities will really help give you a flater curve, so you'll be acurate over a broader range, but you don't want penetration. I think you'd want to stay under 600ft/s and stay in .22 caliber [with a flat nosed pellet this should give more energy to the sting yet be less likely to penetrate than .177 in the same velocity].
I have 1000ft/s [rated] in 22cal and it had no trouble putting a squirrel in the frying pan [never did find the pellet either]. After putting several pellets in the same general area of a phone book, one found it's way clear through; no "bang"...but these things still have plenty of power.
Side note: except some match grade ones with "reverse springs" or other fancy features, the recoil of springers is a different feel, and will beat the heck out of a scope as well.
BTW: I can't remember where he found them, but a guy around here swears by some low velocity .22 rimfire rounds he found; he uses them on stray dogs.
   / 1000 FPS Air Guns (Gamo Hunter) #3
I had one, used it to kill the squirrels that were tearing up my house, and it worked well. Mine came with a big ol scope (which I needed with my eyesight!) and once I got it sighted in, I could hit the buggers in the eye about 30 -40 ft up in my trees. (at least if they weren't hiding behind the branch or trunk.)
Only thing I didin't like about this (and it's the same for all air rifles I think) is that it was single shot. When you broke it open to reload you also primed the pump, so it's fairly quick, but with a large target that shouldn't be a problem.
Squirrels are supposed to have a tough hide, but this thing had no problem penetrating it.
   / 1000 FPS Air Guns (Gamo Hunter) #4
Well, putting a pellet in their rump won't cause any permanent damage, will it?
   / 1000 FPS Air Guns (Gamo Hunter) #5
Another note on this:
If you get enough of a sting for the desired effect, the bruise may last right into hunting season. When I was just old enough to own a Daisy single pump [like the Red Ryder, minus the fancy styling], my older cousins decided to use the chickens as target practice; a month latter when it was butchering time I got my butt bruised, just for loaning them the gun!! /forums/images/graemlins/frown.gif /forums/images/graemlins/grin.gif
   / 1000 FPS Air Guns (Gamo Hunter) #6
Lead in deer; I really don't know.
I can imagine all sorts of ugliness, like gangrene, or other sores, but I really don't know. /forums/images/graemlins/confused.gif
I had one of these break action/single pump rifles as a kid and can't even remember what happened to it. I suspect my Dad gave it to one of his friends kids when I was at college (a lot of stuff disappeared during that time). It was pretty powerful but I doubt it was 1000fps. That was 20+ years ago.
I was hoping to be kind of lazy and just ping them from 50-100 yards. I would think the energy would be pretty low by the time it got that far. Right now I can walk up to them within about 10-20 yards. Kind of wish it was hunting season as I could just pop them off with my 44 Mag and be done with the problem for a year or two.
   / 1000 FPS Air Guns (Gamo Hunter) #8
My Crosman 1077 with 12 shot rotary clip (.177) has worked well for stinging, for me ... usually under $100.
For sub-sonic .22 rimfires, I like CCI CB shorts. As quiet as an air gun but more than just a sting.
   / 1000 FPS Air Guns (Gamo Hunter) #9
<font color="blue"> As quiet as an air gun but more than just a sting. </font>
Cool! /forums/images/graemlins/cool.gif That's about what I heard, except slightly lower velocity yet, so supposedly it was just a good sting.
I think the CCI CBs are over 700ft/s; it seems these were like 500 or 600ft/s.
.22 low velocity
Actually if you're good at judging distance, keeping some of each on hand could really keep your aim and sting potential even, between say 10 and 100 yards [would still need to burn a few of each to get a feel for "where they land"]. /forums/images/graemlins/smile.gif
   / 1000 FPS Air Guns (Gamo Hunter) #10
What kind of range do you need?
If you can keep it under 100', a paintball gun would probably do the trick. Much less zing than a pellet gun, but they do smart, and you could probably tag a deer 5-6 times with a semi if you've got a quick trigger finger.
My guess is, this would also satisfy your "fun" requirement... /forums/images/graemlins/smile.gif
Towable Diesel Tank (A53421)
Towable Diesel...
SDLANCH MINI WALK BEHIND SDLL30 LOADER (A53843)
SDLANCH MINI WALK...
2021 Allmand Bros Maxi-Lite II 20kW S/A Light Tower (A52377)
2021 Allmand Bros...
12ft Heavy Duty Aluminum Ramps (A53473)
12ft Heavy Duty...
2012 CHEVROLET SILVERADO SINGLE CAB TRUCK (A51406)
2012 CHEVROLET...
