100 hr oil/filter change 3525
   / 100 hr oil/filter change 3525
TroyBoy $50 was hat to include the oil? Thats not as bad i thought it would cost. I'll probaley do the oil change this weekend.
JC thanks again for the info i'll make a few phone calls to the part store/dealer and check prices.
   / 100 hr oil/filter change 3525 #15
3325:
I use a WIX 51515... same diameter, gasket, by-pass pressure, flow rate, and thread as WIX 51068. The 51515 is 0.85" longer than 51068, I have had no clearance problems due to the additional length.
WIX 51515 interchanges with NAPA Gold 1515, Motorcraft FL1A, Fram PH8A, etc...
   / 100 hr oil/filter change 3525 #16
3325:
Thanks Phil i take it the extra length is to provide more filtering? or just another good alternate source.
   / 100 hr oil/filter change 3525 #19
A bit more filter element, increases oil capacity a little, convenience of using the same filter on my 3325 and my old truck. (truck actually calls for 51068... same as my 3325)
I use the over-sized filter more for the slight increase in oil capacity, than anything else... price is the same.
   / 100 hr oil/filter change 3525 #20
SET OF (2) TITAN HI-TRACTION TRACTOR TIRES/WHEELS (A51244)
SET OF (2) TITAN...
UNUSED AGT QUICK ATTACH AUGER SET (A51244)
UNUSED AGT QUICK...
2000 INTERNATIONAL 4700 (A52472)
2000 INTERNATIONAL...
2014 Volkswagen Jetta Sedan (A50324)
2014 Volkswagen...
Kubota B7100 Tractor (RUNS) (A50774)
Kubota B7100...
2015 Freightliner Bucket Truck (A52128)
2015 Freightliner...
