BobG_in_VA
Veteran Member
- Joined
- Jul 4, 2003
- Messages
- 2,002
- Location
- Central VA, USA
- Tractor
- Mahindra 6000 MWFD, 2 1950's Farmalls, 1974 Farmall 140, 1967 Mf 135Delux
I turned 104 hours on my 6000 4WD this weekend. I've had it about one year. Repairs: One FEL hydraulic connedtion required a "tighening", the power steering reservoir was replace under warranty due to a leak at the top of the reservoir (not a bad leak, but annoying-- only had to add a pint of fluid in 70 hours). I check the FEL frame mounts for loose bolts on a weekly basis as I've had 3 bolts (all on the right side) loosen a couple of time. I'm not worried about resale of this machine (as some folks make their purchase of a tractor based on how much they can get for it when it no longer fits them LOL) as its got mo' power/mo'traction/mo' FEL lift capacity than I'll ever need as it stands now.
Changed the oil filter at 22 hours and again at 57 hours
Set up as follows:
6000 4WD Synchro Shuttle shift
FEL Md 264 KMW w/ HD toothbar (bought thru Johnsons Auto)
Fluid filled rears tires (16.9 X 28) set up thru dealer
7ft International Machine Co brush hog bought thru Mahindra dealer)
7ft HD BoxBlade (bought from Corriher)
BobG in VA who is happy as a pig in poop with his Mahindra
Set up as follows:
