Very cool, I look forward to watching your progress! Even if the pump isn't there, you can grab one from
Surplus Center for around $350 for a 20gpm pump, which is around what this loader originally came with.
I'd much rather have something older, or resto-modded then a brand new machine. Older stuff just has a certain style that I love. Speaking of which, within the next few years, I'd like to get myself a '56 IH S-120 4x4 pickup, or one of the larger S-130's, put a Cummin's 4bt diesel in it, and enjoy! I can dream, right?
Those having patience will see their dreams bear fruit.
Mack and International trucks are my favorite.
Once bought an old 56 International 3 ton x military with the engine missing and the transmission sitting on the drivers seat. Once home had removed all the glass then blasted to white metal. Painted the truck Emerald green in pearl using Endura, the grill and front bumper is pearl white, then after having to shield my eyes painted over the bumper in green to tone down on the brightness.
The green over white on the bumper was a nice touch. Inside the truck was left in the under base coat green with out the pearl.
Engine installed LT1 350 small block Chevy with the heads reworked for propane, 12 inch clutch coupled to a 4 speed.
Additional work installed a hydraulic pump that came from a fishing boat these have an electro magnetic clutch run by a pair of belts.
With the flat deck, I hinged it at the rear then installed a telescopic ram, a warn 8000 lb winch converted to hydraulic installed at the front of the deck, plumbed the long runs along the truck frame and underneath the deck in tubing, using high pressure hose at the hinge.
The winch could now be now be operated in any deck position, With having the lift cylinder and the winch I had to also install a power beyond valve. What I find so amazing is once you get started on a project and word gets out among your friends is their willingness to dig out goodies from their stashes.
A good buddy had a stash of 12 volt electric spool valves of which he had donated a pair. I installed the electric spools with a long umbilical cord using a water proof toggle from an electric winch.
At the rear of the deck installed a large roller set about half an inch higher than the deck height.
I used the truck to haul scrap cars, and could double deck two then piggy back another.
The only mishap I had with the truck was letting my anger get the best of me, one day I had gone into a field to get a few scrap cars the grass and brush uncut could not see my tracks fort he return trip out of the property and found myself in the wooded section and drove or rather bounced over a large log than was hidden from sight.
Truck was loaded heavy the front axle light so going over the log was easy , the rear wheels had the weight and couldn't make it over, and the front would not go over backing up. So I"m stuck, I get aggressive going from first gear into revers trying to bounce one axle over and I don't care which.
That big 12 inch clutch had a lot of friction surface, I tore the center spline from the disk.
