10 hour service on 2550
   / 10 hour service on 2550 #1
Dascro
SW Pennsylvania
Kubota B7610, Cub Cadet 1450
I completed the 10 hour service on my 2550 today as recommended by the owners manual. Everything went pretty good including changing the hydro filter after lifting the front end up in the air as high as a floor jack could lift. I only lost about 3/4 qt of fluid.
However, while greasing the mower moveable idler pulley, the zerk pulled out when I removed the grease gun. Generally specking, I hate press in zerks!
Anyhow, had to remove the idler pulley assembly, drilll out the zerk hole, cut threads with a tap, and thread in a quality zerk.
All is well and I mowed with the tractor shortly after. But I was a little dissapointed that I had to replace a zerk during the first greasing.
On another note, I applied a second coat of Mo Deck while I was working on the deck (after I cleaned it). I checked it after mowing tonight and frankly am less than impressed with the Mo Deck product. It is quite dry here anad the grass is not full of water at all and I still had the same about of grass clipping build up under the deck. I'll give it some more time and use up the whole can of Mo Deck, but I am beginning to doubt its effectiveness.
Dave
   / 10 hour service on 2550 #2
Ditto on the press in zerks. I bought new spindle assemblies from Cub for my 44C deck when I rebuilt it, and the press in zerks fell out on me too. I also ended up putting on thread in zerks. Some guys say a little loctite will hold the press in zerks in place if you don't want to tap the holes.
-Fordlords-
   / 10 hour service on 2550 #3
I just finished the 10 hour service on my 2544. I found I was missing one lug nut, and one of the deck wash connections is missing. Also I'm not sure where the front axle pivot bolt is, I can't find a grease fitting for it. Other than that all went well . I had a problem with the engine coughing when I shut down but 93 octane seems to take care of that.
Northstar,
The zerk for the front axle pivot bolt is on the "bottom" of the front axle directly at the mid-point of the pivot point for the front axle (i.e. directly under the pivot bolt). At least that is where it is on my 2550 and I see no reason why it would be different on your 2544.
Also, I've seen a lot of remedies on this forum to minimize the engine continuing to "run on" after being turned off. Mine is worse when I try to shut it off after a long mowing session. But I don't think its that bad overall on mine. Given the ever increasing gas prices, running 92 octane may be an expensive fix in the long run. I don't think the sputtering and "run on" hurts anything, its just annoying.
Dave
   / 10 hour service on 2550 #5
On my 2554 I had trouble with the press in zerks too. Like Dascro I pulled the combination pulley and fitted it with a 1/4 X 28 threaded zerk. Some of the others were repaired by the dealer on warranty when my tractor was in for the steering recall. I was going to do the rest on the machine as needed but replacing some of them will require disassembly I don't feel like doing, especially on a basically new $4000 machine.
Talking to the farmers in the area, it seems lots of new equipment uses these darn things. Enough equipment uses them that the auto parts store where my son works keeps them in stock. Looking at my tractor I decided that many of them just hadn't been driven in far enough at the factory. I used a small socket on a couple to drive them in completely and they've been fine through multiple greasings.
I also bought this $5 tool from of all places, Amazon. It should make the job easier in the future -
Amazon.com: Lumax Drive Grease Fitting Tool, Straight: Automotive
As far as engine run on, I've not seen that. I shut the engine down at 3/4 - full throttle. That's the procedure I've heard to eliminate back firing. Even though I don't like it doing it for some reason, that's what I do and I've never had a problem.
   / 10 hour service on 2550 #6
Dave,
Thank's I found the pivot bolt fitting, right where you said it was. 93 octane is a little more expensive, and I tried to throttle back before shutting her down but it still backfires. I could live with it if it weren't for the smirk on my neighbors face (JD owner). Thanks
   / 10 hour service on 2550 #7
Northstar said:
Dave,
Try leaving the throttle wide open when you shut down and see what that does...
   / 10 hour service on 2550 #8
Yep, like JS says, you have to kill the ignition while the engine is throttled up. This procedure is in the ops manual. It doesn't feel 'normal' but you'll get used to it real quick after a few shot-gun bangs. I would hate to blow one of the 2 or 3K series mufflers apart, I bet they are pricey buggers.
Joel
Happy to have been able to help you out a little, Northstar.
Dave
   / 10 hour service on 2550 #10
Hey guys, not to hijack the thread, but I saw the comment about a steering recall. I have a 2005 GT 2550 and never received anything about a steering recall. Does anyone have any detail on the recall?
Thanks.
2017 John Deere HPX615E Gator 4x4 Utility Cart (A51694)
2017 John Deere...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A52377)
2015 SkyJack SJ86T...
UNUSED Clear Multi-wall Polycarbonate Pane (A53117)
UNUSED Clear...
Bobcat 14in. Excavator Bucket (A53117)
Bobcat 14in...
2012 CATERPILLAR 304E CR EXCAVATOR (A51242)
2012 CATERPILLAR...
