10' heavyduty Shedder/mower
/ 10' heavyduty Shedder/mower #1
misty
1256 IH
The gear will turn,but the center of the gear will not. It will only turn when I:confused2: spin the blades by hand
/ 10' heavyduty Shedder/mower #2
probbaly need a lil more info.
Are you trying to say that the pto shaft turns, but the input shaft to the mower does not?
if so, look for a hole for a shear pin, or if it has a slip clutch, then a locking pin.
if this is not what you were talking about, post back.
PS.. welcome to TBN.
soundguy
/ 10' heavyduty Shedder/mower #3
Or you broke a spindle shaft in the gear box...
Let us have make and model and a bit more description of what is going on.....
/ 10' heavyduty Shedder/mower #4
if he see's a visible part turning on the outter, and an inner part not turning.. that seems to me the input shaft, not the 'invisible' spindle shaft.. but yeah it's all a guess without a pic.... .. a picture and some line drawings / markup would be more clear.. or a look at the parts listing and call out the problem areas by name.. etc.
soundguy
2015 John Deere 8345R (A64119)
2015 John Deere...
2024 B and B Fabrication CT3500MRT Towable Reel Tensioner (A61572)
2024 B and B...
2018 Peterbilt 579 Sleeper 72" Sleeper (A62613)
2018 Peterbilt 579...
Bulk Lot - Used Steel Transfer Pipe & Fittings (Chuck Pipe) (A63689)
Bulk Lot - Used...
2011 GREAT DANE 7211TZ 53FT T/A REFRIGERATED TRAILER (A59912)
2011 GREAT DANE...
Katolight SED60FJJ4 75kVA Towable Diesel Generator (A61572)
Katolight...
