10 ft disk
   / 10 ft disk #1
Otter lake
John Deere 3020
Will my 3020 John Deere properly pull a 10 ft 3point disk
   / 10 ft disk #2
Depends on your ground and how fast you wish to pull it and how deep,
you are marginal, duals would help.
   / 10 ft disk
Trying to take some roughness out of hay field do I maybe need an 8 or 9 ft
   / 10 ft disk #4
I pull a 10’ disk with a Case 485 just fine. I’ve now got a JD 5425 (81 HP) that I’ll use to pull it with now.
   / 10 ft disk #5
The type of ground is not know.
Sandy loam, sticky clay, hardpan and rocks, gravely it will make a difference.
Discing up sod will be easy the first pass as far as traction.
Trying to get roughness out of a hay field will take several passes with a disc and the front to read setup and the angle of the disc will have a major effect on your results.
   / 10 ft disk
How much weight will a 3020 3 point lift
   / 10 ft disk #7
If I was looking for a disk for a 3020 and for what your are doing I'd be looking for a pull behind and not a 3 point.
   / 10 ft disk #8
A 10" will be too heavy for a 3020, unless you have some serious weights on the front. Even with weights, the hydraulics probably won't be strong enough to lift it.
If it were a 10' pull type disk with wheels, you would have no problem with the 3020.
   / 10 ft disk #9
Wait! What year 3020? And diesel or gas?
400 gal Fuel Barrel on Skid (A50515)
400 gal Fuel...
2015 Hamm H7i VR-3 Single Drum Vibratory Soil Compactor (A49346)
2015 Hamm H7i VR-3...
2020 FREIGHTLINER 26FT BOX TRUCK (A51219)
2020 FREIGHTLINER...
2016 FREIGHTLINER M2 REFRIGERATED BOX TRUCK (A51222)
2016 FREIGHTLINER...
2020 EZGO GOLF CART (A50324)
2020 EZGO GOLF...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A52128)
Kubota 24in Quick...
