1 tractor rest of forever -- what brand?
   / 1 tractor rest of forever -- what brand? #41
They are leaking internally, not externally. When I first got the tractor, when picking up something heavy with my forks, I could lift the loaded rear tires off the ground, even if I had my rear blade on it. Wouldn't happen if I had the backhoe on it. Now it won't lift the rear tires even with no implement on the back. It is not uncommon for the piston seals to roll/leak in these tractors. No intention of taking it to the dealer. I just need to find the time to figure out which cylinder is leaking, pull it and replace the seals.
If the cylinders are leaking internally the loader will not hold position, that is the frame will drop or the bucket will dump with the control in neutral. If you suspect it is an internal leak use a piece of pipe, screwdiver, or what ever place it against the cylinder and you will hear the oil bypassing.
If the frame or bucket doesn't drop I would suspect either the relief valve is bypassing too soon or the pump is leaking internally. To check relief valve again the ole pipe trick may work, or plumb in a pressure gauge. The same applies to the pump except two other "tests" does it lift better with the oil cold and/or does increasing the engine speed help?
   / 1 tractor rest of forever -- what brand? #42
I would guess that Kubota is the most popular compact tractor these days. Thinking that it and John Deere are 1 and 2? So, I have a Mahindra but I might sell it in order to get exactly what I need in a tractor. Primary needs are pasture clipping 7 acres and use in a 50-acre woodlot for managing trees and trails. Was thinking that JD or Kubota would provide...
- parts availability
- dependable
- design
- performance
- ease of maintenance
- resale ability down the way
- plenty of dealers
If you could find exactly what you want in a tractor, what brand would you buy? Being as dependable as possible, easiest to maintain, parts availability and ability to resell down the way are very important in this discussion. Easiest to maintain probably No.1 because I am age 70 and do maintenance and repairs that I can but I am not the type that relishes tinkering, lol, plus, I work alone mostly. Buying used would be great if one is found but not averse to buying new if have to. Should be my last tractor.
Doesn't have to be JD or Kubota but that's my thinking.
TIA!
I think Kioti would be number 3 overall. But for me Kioti is number 1. I purchased the CX2510 to replace a much loved but significantly smaller Kioti CS2410. Other than one hydraulic line that failed prematurely, I've had great success with the brand.
My search started long ago and originally focused on JD and Kubota. I quickly realized that I just didn't want to spend the extra 40% for the JD that needs special proprietary loader attachments and I just couldn't get used to the shuttle pedal design on the Kubota, my ankles just aren't as flexible as this design needs.
So I then looked at Kioti and Mahindra. I ruled out the Mahindra quickly as I just didn't like the design and fit and finish and they have some really bad reviews. I'm also keenly aware of the country these tractors are made in. I think the Koreans are second only to the Japanese when it comes to design and development of anything with a motor.
That and the JD was a full 20000 more then my Kioti. That money buys a lot of quick attach toys for the loader like a grapple and forks.
But I do think that JD and Kubota are great tractors and to be honest, it's much easier to buy parts for a JD or a Kubota. But Kioti is getting better in parts availability.
I hope this helps
   / 1 tractor rest of forever -- what brand? #43
My normal response to all such questions is "shop the dealer." If you can't get parts and service conveniently and with a good attitude from the shop, buy a different brand.
"Forever" is a long time from now, IF the mfg. no longer makes the part that you need, it doesn't much matter what dealer you have.
LESS parts to go wrong is MUCH better, simpler means easier to figure it out yourself.
Not everyone is an electrical engineer to keep one of today's tractors going, so the less of that junk the better!
An example is, engaging the PTO. What do you think is more reliable, a lever with a cable, or an electric switch with a solenoid and a hydraulic powered clutch pack.
Maybe even a puter to "feather" the PTO in, VS. a lever and your arm, to slowly move the lever to feather the PTO in.
My neighbor bought a new deere, he hates it for several reasons and one of them is, when he has his double Kuhn hay rake on it, the PTO switch slams the PTO on. The deere dealer says it's how they work, it's working normal.
SR
   / 1 tractor rest of forever -- what brand? #44
Tractors built before the 80's were built simply and easy to maintain by the owner, tractors then started to get "electrified" and became harder to self maintain, currently tractor contain computers water and rodents along with normal wear and tear can make the unreliable and expensive to maintain, and the emmissions equipment doesn't help any either.
At 73 a few years ago I picked up a MF 245 that needed work, was able to find a 232 loader with the right brackets so I am happy with my "forever tractor".
As has been stated before if I was going to look for another tractor I would check out the online classifieds and see what a potential purchase was selling for and the availability of that model, then I would check the wrecking yards for used parts availability.
I used to work for a MF dealer so I prefer MF of course. The older 135, 165, 175, 230, 245, 255, 265, 275 were pretty reliable tractors that used fuel efficent Perkins diesels. Just a warning though the tractors with the swept back front axle were not the best for loaders and avoid a 235 as they had a "new improved" steering gear that was weak.
   / 1 tractor rest of forever -- what brand? #45
Might as well rebuild them both. I remember going to the local NH dealer and buying a kit for 1 lift cylinder. The parts guy told me “I got one more kit - you want it? Your gonna need it!” I didn’t buy it but in about 6 months I needed it for the other cylinder!
   / 1 tractor rest of forever -- what brand? #46
SR
You have to lower RPMs before engaging an electric PTO, then raise them as the implement is engaged.
   / 1 tractor rest of forever -- what brand? #49
Absolutely, but that's not possible on my neighbors new deere, it idles at a 1,000 or more RPM's and the dealer says that's for emissions, can't lower it and can't feather it in.
My AGCO's idle at less than half of what his deere does, as does his older tractors.
SR
   / 1 tractor rest of forever -- what brand? #50
I have several Kubotas. I have not looked at a Kiota ina long time. But back when I did they were very well built. The frame and the loader looker extremely tough. U dear the hood, it looked like they took a Kubota engine apart and copied it, right up to the oil filter placement.
2024 New Holland T8.410 MFWD Tractor (A55314)
2024 New Holland...
2021 Ford F-150 Ext Cab 4X4 Pickup Truck (A55852)
2021 Ford F-150...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
2025 BrushFox XHD-78HF 78in Rotary Brush Cutter Skid Steer Attachment (A56857)
2025 BrushFox...
Mini Skid-Steer Hydraulic Side Shifting Forks (New/Unused) (A59225)
Mini Skid-Steer...
16' METAL TRUCK BED (A52708)
16' METAL TRUCK...
