bigtiller
Super Member
- Joined
- Feb 1, 2006
- Messages
- 7,469
- Location
- central Iowa
- Tractor
- John Deere 2720 John Deere 3039R John Deere Z545R
I think 1 inch low in front on a 20 foot trailer while fully loaded is a pretty good "target" to aim for.
If 1" low is outside your comfort zone, I respectfully submit that you are overthinking this by a wide margin.
There are "bumper pull" drawbars rated to 20,000 lbs, I have a couple.
I've also used gooseneck balls in said drawbars to get a ball rated higher than the drawbar, works fine.
There are also receiver hitches rated to 15,000 or more, regardless of what the truck manufacturer says. Have one of them too.
Buyers Forged Ball Mount — 2in. Drop, 1 1/4in. Ball Hole, 20,000-Lb. Capacity, Model# 1803051 | Ball Mount Hitches | Northern Tool + Equipment
It's hard to read the parts you have circled. What year is this spec sheet from? Maybe it's an older one and that's why it has the 10,000 lb restriction.
I looked at the current Ford and GM guides online and they seem to range 12.5 to 17K for conventional towing.
My 4 year old 2008 GM owners manual says 13,000 lb max for a weight distributing hitch. The current 2012 GM guide is a little higher, up to 14K for the gas and 17K for diesel dualies with drawbar ball hitches.
Yep, trucks of even 10 years ago do not hold a candle to todays trucks.
Chris
Well, I am not sure that I agree that the trucks don't hold a candle to todays trucks, but maybe I will agree that Ford has raised the vehicle load ratings of the newer trucks.(probably to keep up with the ever changing ratings of the competition) I would probably put my 7.3 up against most any of todays trucks in a lonegivity test with a couple of tons in the bed. The older ones have a better reputation, on which the new ones are riding the coattails of. The 2011 and up are gaining a better rep than the ones before them, but doesn't make them better than the 10 year ago trucks.
David from jax
Yes it is fully loaded and the truck has a "permanent" load on it as well so there is no potential for additional sag with more load.
I am like you I never want the front down, but 2" high is a bit. I can see the springs on the trailer axles not level and it looks like it is putting more load on the back axle.
Doesn't having the trailer nose low add weight to the back truck axle when brakeing and having it trailer nose high reduce weight on the back truck axle?
I would put any 05 or later 1/2 ton up against any 3/4 ton gas made in the mid 90's any day of the week.
Chris
No.
It is (SHOULD be) the other way around.
I agree with that 100%
Actually, it doesnt matter either way. The weight transfer is a result of the velocity change, and is going to add weight to the rear wether it is 2" high or 2" low.
In theory though, an EXTREMELY high tongue could cause weight to be taken off, but the truck would have to be raised up in the air like bigfoot with an 8' high hitch, coulped with a low trailer AND no trailer brakes. But an inch or two either way, the difference would be immeasurable.
And to throw more confusion at you'all, "level" for purposes of figuring above is NOT the level of the hitch-to-bed.
You would have to actually draw an imaginary line from the hitch THROUGH the center of gravity of the trailer. AND this center gets MUCH higher with a tractor/car strapped on. So with a load, the CG is going to be WELL above the hitch. Thus a downward angle, and braking will ADD weight to the truck. Again, with a tractor on a trailer, the CG is going to be ~6 foot in the air, and the hitch @~20".
And all this is negating the fact of trailer brakes. Trailer brakes is naturally going to ADD weight to the tongue because the CG is well above where the tire meets the road.
Guess matter of opinion. I have owned well over 15 trucks and can tell you they get better and stronger each and every year in my eyes. I had a 99 F-350 7.3L and it was a good truck, dont get me wrong. Especially for the time but my 06 F-350 is much more truck and my dads new 2011 is much nicer then my 06. Its just the way it works.
Chris
