1 Blue Out 2 Orange In
   / 1 Blue Out 2 Orange In #1
hard_yakka01
Oakland, ORYGUN
NH TN75D, Kubota M105S, M8200N
Well after getting nowhere with NH Corporate on all the issues I've had with my TN75 I bought Kubota's today, M105S and M8200N. They will be delivered next week. They are more utilitarian in appearance but are lighter than NH equivalents, only time will tell.
   / 1 Blue Out 2 Orange In #2
I have no clue as to the problems you've had. I tried to see what previous posts you've made, but the subsequent page comes up "no matches."
Sorry to hear you've had so many problems and the NH didn't help. Good luck with the new Kubota equipment. John
Somehow my 'hard_yakka' login has been lost, did you try using that?
   / 1 Blue Out 2 Orange In #4
</font><font color="blue" class="small">( Somehow my 'hard_yakka' login has been lost, did you try using that? )</font>
I clicked on your name and then show all user's posts and came up with nothing /forums/images/graemlins/confused.gif John
   / 1 Blue Out 2 Orange In #5
Scott,
I just did a search using hard_yakka , and I got a listing of your posts back to 10/30/03.
How far back did you first register?
Should have been 35 or so postings using hard_yakka. Oct '03 sounds about right for registering, before that I was a lurker /forums/images/graemlins/smile.gif
My second post or so starting talking about the issues we had with the TN right off the truck.
   / 1 Blue Out 2 Orange In #7
I can't help you with getting your first username back. That's a Muhammad problem.
But if you want to see all of the posts that you made, just use the Search feature. But make sure that in the Words To Search For window, you type your first username in exactly as it was when you registered. Then, in the Search Options Window , open it and use the By Display Name option. And last, make sure that in the Date Range window, you open it and click on All Posts .
That should show you all of the posts that you made under the username of hard_yakka. /forums/images/graemlins/smile.gif
Hope this helps.
   / 1 Blue Out 2 Orange In #8
</font><font color="blue" class="small">( That should show you all of the posts that you made under the username of hard_yakka. )</font>
Gary, do you have any idea why his 10 current posts are not showing up uner "show all user's posts?" I just clicked it again, and still no matches. John
Here is a quick 'view' of the problems asked by someone else on another forum.
Another complaint is that I've asked for each warranty/work done receipt like the the car dealers give out and have received nothing so here is my recollection.
1) At delivery BH would not operate without tripping remote off, BH non-functional.
2) Replaced remote, still doesn't work
3) Replaced remote valve stack(??), BH still doesn't work properly but now (4) transmission idiot light comes on 'do not operate'. Dealer goes bankrupt, tractor non-functional with 38 hours. I left the country but my son is available to run equipment. Threat letter to Mr. Kennedy, President NH finally results in some activity
5-6) Complete electrical failure of cab x 2.
7) Airconditioner system looses all coolant, service mgr tells me that the wrong hoses were installed at mfg.
8)Doors hinge 'C' clips have popped off both sides, 1 door hinge pin gone, so one has to crawl over right side to get out otherwise left door falls off if you try to open it.
9) Shuttle shift only workes with clutch.
10) Fuel sender is dead...
11) FEL connections on 2 lines leak, 1 line has popped off and no matter what I do (unit off, no pressure on line) I cannot get disconnect reconnected.
Transmission idiot light pop's on about every 4-5 hours and then goes off but there is plenty of fluid in the system.
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
2015 Freightliner Bucket Truck (A52748)
2015 Freightliner...
2019 Ram 2500 Pickup Truck, VIN # 3C6UR5DL0KG545677 (A51572)
2019 Ram 2500...
2000 FORD F-350 SUPER DUTY BUCKET TRUCK (A52472)
2000 FORD F-350...
2003 Lincoln LS Sedan (A50324)
2003 Lincoln LS...
